Looking for microcontroller cheaper :)
Hi Folks,
Ii'm not experiece guy in eletronic .... sorry about that
I'm looking for a microcontroller cheaper for my final project..
I made tests using Attiny85, nice controller but quite expansive.
My program datas:
Sketch uses 2412 bytes (29%) of program storage space. Maximum is 8192 bytes.
Global variables use 19 bytes (3%) of dynamic memory, leaving 493 bytes for local variables. Maximum is 512 bytes.
Ports that i'm using at Attiny 85
*Runing at 8Mhz
*2x Analog port A3 and A4
*1x digital input
*2x digital output
  • powered by 3,7V - 18650 Battery
Aditional data using #include "tinysnore.h" for put uC to sleep mode save battery
Any suggestion for uC cheaper ?
If i can use arduino interface should be better
I'm anxious for hearing suggestions :slight_smile:
Have nice day!
  • Cheaper than what ? $ :thinking:
How much are you paying for the Attiny 85 ?
Hi :slight_smile:
Cheaper maximum as possible hahahahahaa
I'm paying close to 2 Uss :confused:
How many of the processors does your project use ?
one for each PCB
How many PCBs and how much does each PCB cost and what other components are used ?
How is the PCB powered ?
In fact, what percentage of the cost of a single instance of your project, whatever it is, does 2 USD represent ?
it's a starter project from now few pcs but I would like to use cheaper controller looking to the future.
otherhan, I will develop my PCB, I would like to develep as well with final controller
Powered by 3,7V - 18650 battery
Out of interest, how much does the 18650 battery and a suitable charger cost ?
Can you see what I am getting at ?
Yes I got it :slight_smile:
Close to 5uss not to much ...
Attiny if you look size means 2uss .... battery and charger 5uss
What currency are you working in ?
Bare chips can cost more than development boards if ordered in single units.
If you want arduino compatible chip, have a look at stm32c0 or attiny402
Interesting :slight_smile: I will investigate more
Maybe another type of attiny family should be option
Tkssssssss
In Brazil is called Reais .... today is 6 times less tha dollar
1uss = 6 reais :frowning: ...... :hot_face:
Did you look at WCH e.g. CH32v003 https://de.aliexpress.com/item/1005004895791296.html ?
If you don't use voltage regulator, you need to find a chip that can run at 2.7-4.2V
Thanks. It was your use of uss and the currency specifier rather than the more normal USD that made me ask
Thank you guys for help me :slight_smile:
I really apreciatte it .... i will investigate ch32v003f4p6 right now :slight_smile: it's seens very interisting .. my circuit is really simples.
Keep controller at sleeping.
Receive a signal from IR receiver.
awake controller
wait timer 1
Turn on output
wait timer 2 keeping output high
Turn off
back sleep
ATtiny09.
US$0.72 per unit:
https://www.mouser.com/ProductDetail/Microchip-Technology/ATTINY9-MAHR?qs=lwdSMh1%2FoYLZt9Cg0MwMzw%3D%3D
Datasheet:
https://www.mouser.com/datasheet/2/268/8127_125-3445024.pdf
In use:
Just thinking differently :smiley:
Maybe a NE556 dual timer IC with some external components for the timing will do . Or a handful of discrete components (transistors, capacitors and resistors).
No design in mind.
