Looking for multifunctional module: LCD, voltage+current+temperature sense, speed control, load cut, buzzer
?arduino??
LCD??????????????????????????PURGE???????????
Please post your posts in English as the forum does not have a Taiwanese section.
Hello: want to ask whether there is a suitable module for use with the arduino inside with LCD monitor, voltage sensing, current sensing, temperature sensing monitoring, speed control, PURGE control, load cut off, the buzzer will these connections to my load above is there anything you can do these things Thank you!!
qa123692002:
No. That is an entire project you have to make it yourself.
I know, but I want to know is, is there to make these Arduino Boards thank you.
qa123692002:
Your English question is hard to understand for me. There are a lot of open questions (between() )
I interpreted your question as follows:
Which Arduino board do I need to make a project with:
  • LCD monitor, (yes, grafical, text, what size?)
  • voltage sensing, (yes, what range, accuracy?)
  • current sensing, (yes, what range, accuracy?)
  • temperature sensing monitoring, (yes, what range, accuracy?)
  • speed control, (yes, speed of what? does it include measuring speed?)
  • PURGE control, (please give more information what you mean by this)
  • load cut off, (please give more information what you mean by this)
  • buzzer (yes, what kind of buzzer, small large?)
In short I expect an Arduino UNO would be adequate, but you must describe your project in far more detail to be sure.
Also which sensors (LCD, buzzer) to use for the above project is hard to advice as you do not provide any specification.
So please write in detail the goal of your project and the specifications of the sensors, LCD and buzzer.
Ok, thank you
  1. LCD 20 * 4 LCD module ( Like this file:///C:/Users/ardeng/Desktop/133670262801332056412.pdf)
  2. Measured voltage sense ( Range?0 - 50V Accuracy?±0.5 )
  3. Current Sensing ( Range?0 - 30A Accuracy?±0.5 or ±0.5 )
  4. Temperature sensing monitoring ( Range?0° - 60°C Accuracy?±0.5 °C or ±1 °C )
  5. Fan Control ( Voltage: 12v . can control the strength of the fan. )
  6. Purge control ( Purge interval can be controlled and Purge make up time )
  7. Load off ( Is a protective mechanism. Read voltage or current sensing sensing. Decide YES or NO to start protection )
  8. Piezo Buzzer ( 3V - 15V, 85dB, 5mA(9V )
Thank you
qa123692002:
Sorry, we need a link to the place on the Internet where the picture is, preferably the page on which it is sold. You have cited a file on your own computer, to which we have no access.
To upload a picture from your computer to the forum server, use the " Additional Options..." below the reply window to "Attach" the file. You can modify your previous posting.
Paul__B:
qa123692002:
133670262801332056412.pdf (1.09 MB)
