Looking for plcc-4 prototyping boards
I'm looking to see if I can find some PCBs that I can mount several PLCC-4 style LEDs for testing a project I have started. One format that would be desirable, but not required, is similar to a Surfboard brand item from Capitol Advanced Tech. These adapt the on board SMD device to pins that fit into a breadboard. I don't need breadboard capability, but it probably would be useful. Anyone know of anything like this?
Thanks for any and all help
Lyle
Try these guys
http://www.proto-advantage.com/
Will purchase the parts and install them onto boards also if you want.
Thanks, I took a look at those and will keep them in mind for future possibilities. I went with a Capitol Advanced Tech one that while it's not a precise match in foot print it's close. The device the board is laid out for is a SOT343 pattern, the pad centers differ by .2 mm. Since each side is only a pair of pads there won't be an error accumulation, just a .1mm (if that) 'overhang' for each lead.
Lyle
