Looking for Project Help
I’m trying to make a project that essentially runs a motor until a certain amount of objects pass through an ir sensor. I cant completely figure it out. I would appreciate some help. Here is my code:
int relay = 9;
int count = 0;
int x = 0;
const int ProxSensor=A0;
int inputVal = 0;
pinMode(relay, OUTPUT); //declare relay as output
pinMode(13, OUTPUT); // Pin 13 has an LED connected on most Arduino boards:
pinMode(ProxSensor,INPUT); //Pin 2 is connected to the output of proximity sensor
Serial.println(analogRead(A0)); // this will print the IR sensor value.
delay(100); // printing delay.
if (x < 5) {
digitalWrite(relay,LOW); //turn on the motor
if(digitalRead(ProxSensor)==HIGH) //Check the sensor output
digitalWrite(13, HIGH); // set the LED on
digitalWrite(13, LOW); // set the LED off
x = count++; //counter for how many times led turns on
delay(100); // wait
Serial.print(x);
else if (x == 5) { //runs loop 5 times then stops
digitalWrite(relay,HIGH); //turn the motor off
exit(0);
What's the problem?
Please remember to use code tags when posting y
Please use the code button </> when posting code so it looks as follows. Also, if you use the AutoFormat tool to indent the code consistently it makes it much easier to see which parts go together
int relay = 9;
int count = 0;
int x = 0;
int inputVal = 0;
    if (x < 5) {
            delay(100);              // wait
        Serial.print(x);
        exit(0);
Why are you using analogRead() with A0 in one line and digitalRead() with the same pin (called proxSensor) on other lines?
…R
I just attached my current code. So right now, I am trying to use a relay and an IR sensor in my setup. Right now I have the relay motor turn on until the IR sensor has counted 5 objects pass past it. Once 5 objects pass, I want the relay to turn off, turning the motor off. I am a bit confused and any programming issues are most likely from me piecing different codes into mine that I thought would work. Right now, it is just counting 5 seconds and not the number of loops. I am lost on how to fix this. Thank you guys
pool_chem2.ino (1.12 KB)
Please post your code.
In code tags.
int relay = 9;
int count = 0;
int x = 0;
const int ProxSensor = 8;
int inputVal = 0;
pinMode(ProxSensor, INPUT); //Pin 8 is connected to the output of proximity sensor
x = 0;
while (x < 5) {
digitalWrite(relay, LOW); //turn on the motor
//delay(2600);
//digitalWrite(relay,HIGH); //turn the motor off
//delay(2000);
if (digitalRead(ProxSensor) == HIGH) //Check the sensor output
delay(100);
delay(100);
Serial.print(x);
// wait
//x++;
//for (x == 5;) { //runs loop 5 times then stops
digitalWrite(relay, HIGH); //turn the motor off
exit(0);
exit(0); What's that doing there?
Please remember to use code tags when posting code
I used the exit to stop the code so it wouldn't keep looping
I just figured it out. I increased the delay after the count and it now doesn't count as fast and works
jgaiser2:
You have proven to be hard learning and not taking any advice over the last few posts, but still a little note about delay.
You're not allowed to use delay() in your code until you know why that is.
Whatever approach you use to turning the motor off after 5 pieces have passed, do you ever need to be able to restart the process to count another 5 later in the day? Or is this literally only a once-off count to 5 after the Arduino powers up?
(You didn't say what the application is, but I'm picturing a conveyor belt delivering 5 parts to shoot them down a chute into a box, or something along those lines. IRL it's likely you would want to do that many times a day, and re-starting the Arduino is an ugly way of catering for more than one box to be filled.... I'd be very inclined to consider adding a startButton to fire it up again.)
OP I have written a sketch to do what you want that:
  • Uses a state machine approach, which you can read about here
  • Implements the state machine with switch...case
  • Uses the state change detect technique to act when the sensor becomes unblocked
  • Uses blink without delay to blink the built in led to prove the main code doesn't block anything
  • Has a start button, to kick the process off whenever you need it, including the first time
Post back if you want the code...
State diagram below:
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html .
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks… Tom… :slight_smile:
It looks like the OP has found out a way to make his project work, and has scarpered. He may not have the taken the best route, and he may not have taken advantage of the free advice you guys give out, but don't think it was all in vain. I am sure I am not alone in reading the threads of others to try to make sense of this (these!) crazy computer language(s). I have gained greatly from listening in as you help others, and many others will have gained vicariously too.
Particular thanks to meltDown in thread #11 for posting a link to GrumpyMike's tutorial on state machines, arrays, and the like. Like most people I will stick with the simple code that I know how to use until the simple code is not good enough to do the job at hand, only then will I progress to more 'complex' code.
Anyhow, this is just a note to say thanks for keeping me up late into the night....again!
GM
Glorymill:
It looks like the OP ..... has scarpered.
It's less than 48h since s/he was active in this thread.
