Hello,
I am working on HW to replicate the Fizeau experiment for measuring the speed of light.
The geist of the experiment is to bounce a light source (laser) on a far away mirror while passing the light through a rotating crenelated wheel on the way out and in.
If the rotation is slow enough that the "hole" that let the light go out is still "there" on the way back, you will see said reflected light. if the rotation is fast enough, then the hold would have moved away just enough in the time it took the the light to cross the distance, and if you know the rotation speed of your wheel, you can know how fast light travels...
I am therefore looking at building an arduino based system to spin a crenelated disk at a precisely controlled speed (ie, a speed that I can adjust using up/down keys).
My problem is what type of engine can I use?
Nema type motors seems to be limited to around 5 turn per second. Steppers would be GREAT for this application because you control them very precisely, BUT is there any stepper motor that can turn at 50+ RPM? (note, since the only thing that the motor turns is a no load wheel, there is... well no load!)
DC motors can turn faster, and I can use the crenelation in the wheel to mesure it's speed and control it, but how precisely can I control them? how are they actually controlled? a 8bit PWM is most likely not precise enough for my use!
The SW part is not an issue for me as I am a developer in my "real life"...
but I just don't know what to use on the mechanical side of things...
more info:
Distance traveled by light in my experiment: 2*7KM=14KM = 46micro seconds
360 "notches" in the wheel means that I need to move the wheel by 1/720th of a turn in 46micro seconds or do one turn in 33milli second = ~30turn per second...
I can re-use the notches to measure the speed, meaning that I need to do the measurement fast enough on the arduino to aquire a signal at 21Khz, which should be ok, or I can put a second, less dense, set or holes to do that...
Cyrille
