Looking for some help, need simple code for project
Hi dear Arduinist or Arduinista being a harware guy i'm looking for some software help: With the Rainbowduino(latest model out) i built a 12h clock-dial with 144 leds, thats one for each 5 min. Now i need code that steps up one count (one led) each 5 min. Someone outthere?? Could n't be too difficult, but writing code is not my cup. Promise you my first proto for a helping brain. Thanks, Jacob
You should probably get a realtime clock (RTC) chip to track time. The Arduino is not very good at it.
    int hour, minute;
    hour = RTC.GetHour();  //  Get the hour (0-11) from the RTC chip
    minute = RTC.GetMinute();   //  Get the hour (0-11) from the RTC chip
    int ledIndex =  ((60 * hour) + minute) / 5;
How bad is the time keeping ?
I was planning a project using the arduino as the clock -- but it also will have a GPS clock
If the arduino is +/- 5% or so it would be OK for this project -- else, GPS I guess
thanks for the info
if you want a software RTC try swRTC library (its an open source one). But if you have lack of knowledge to implement something as simple as a step up counter like the one you just said, dont you think its too big a project for you ?!? Maybe start with smaller experiments, that will give you a better insight into the things you need to implement, but with simpler approaches, to start with. NOW THAT WOULD BE REWARDING !!
ps- Talk about swapping a salame for a pig !! lol
SolarPanels: How bad is the time keeping ?
The Arduino might be off by minutes a day but if you correct it with GPS time once an hour or so that shouldn't be a problem.
Thank you, John
If it is only a few minutes a day I probably can correct just once a day and be OK
