Looking for some sample ESP8266 programs ?
Im looking for some sample ESP8266 programs that use LED strips.
I have programmed several sketches for the Arduino UNO that use LED strips, but now I want to have some user input using a iPhone, so that's why I am now using a WiFi capable board (ESP8266).
Anyone have some samples or some good links to a few programs?
Thanks!!
Lots of them here
When using an ESP to control WS281x ledstrip in combination with it's wifi capabilities, make sure to use a library that supports DMA or UART mode like Makuna/NeoPixelBus and do not use bit-banged methods as the temporarily disabling of interrupts disturbs Wifi connection.
Deva_Rishi:
When using an ESP to control WS281x ledstrip in combination with it’s wifi capabilities, make sure to use a library that supports DMA or UART mode like Makuna/NeoPixelBus and do not use bit-banged methods as the temporarily disabling of interrupts disturbs Wifi connection.
This is true, but I ran a Christmas display using three Wemos D1 Mini’s. I also was using the OTA library to facilitate remote programming of the ESP’s. I never ran into a WiFi problem during the uploads. (I suspect that once the OTA code was started that interrupts were turned off.)
During uploads all processing is dedicated to Wifi. The problem occurs when using bit-banged method to send a ledstrip signal, due to it's timing sensitive nature, interrupts would have to be turned off, which usually causes connection problems.
