I have a project and I need a professional Arduino programmer to help me. If you are familiar with a Neurosky Mindwave Headset and Arduino UNO read the following description:
I have a Neurosky Mindwave (white) color with RF USB dongle, the RGB LED, Arduino UNO r3, and Two servos. The Neurosky Mindwave can read attention, meditation, and eye blinking. I want an Arduino code that make me able to use Eye blink detection. For example, When I focus, the mind wave read attention and servos move forward. When I wink, the Neurosky Mindwave stops read the attention and moves to the Eye blinking mode. In the Eye blinking mode, the RGB LED turns respectively Red,G reen, and Blue. the RGB LED should change the color slowly which means each color takes 5 seconds. If I wink on the Red color, the RGB turns Red for 5 seconds and turns servos to the right then back to the Eye blinking mode where I see the RGB LED turns respectively Red,Green, and Blue. If I wink on the Blue color, the RGB turns Blue for 5 seconds and turns servos to the left then back to the Eye blinking mode where I see the RGB LED turns respectively Red,Green, and Blue.If I wink on the Green color, the RGB turns Green for 5 seconds and allow the Neurosky Mindwave to read attention which makes servos move forward again.
If you can implement the code, please contact me via the following to get more details about the project and the budget:
thank
