I am looking to hire for multiple projects, the first of which is detailed below. This is for a long-term relationship, not a one-time gig. Must be with someone who is available to chat during normal business hours, and can deliver a quality product.
Preferably looking for someone in central NJ that can help with installation and setup. Please contact me at seraslibre@gmail.com with a budgetary quote, where you are located, and your business information (if any).
Multichannel temperature logger;
6 channels
Each channel supports Type J, K, T, E, R, S or N Thermocouple Inputs with miniature thermocouple connectors
Data storage
Onboard removable SD card
Power
Plug in power via 120V 60hz outlet.
Temperature acquisition
Resolution: 0.5 degree (F/C)
Accuracy 0.5 degree F or better
Configurable parameters
Temperature units
Calibration adjustment for each channel
Date and time (or pull from network?)
Datalogging rate range from 1/sec to 1/day
Datalogging continuous loop or stop when card full or to network folder
Sample period, number of samples, scheduled start and stop time
Channel active/disable
Display type - graph, current temperatures,
Assign channel names
Temp range for each channel
Files on SD card;
Temperature log with timestamp
Config file for setting parameters
File format: csv
Indicators;
Blue for power on and wifi connected
Flashing blue for power on and wifi not connected.
Green for logging active
Flashing green for channel fault (open circuit on active channel)
Controls
Reset button – for software reboot
Flag button – record flag in datalogging file for each press.
Logging start/stop
Provided in sealed enclosure.
Wifi connectivity with ability to copy data onto network share.
