Hi Blimpyway, thank you for the reply.
Per my comment of pairing the physical portion to the app, poor wording on my part. I DO need the app written along with having the sensor built.
Per your other comments:
- the vibration ranges - min/max frequency, min/max accelerations
I am unsure of these at the moment. Not sure what's possible with Arduino materials. For the sake of this project, I am trying to build a proof of concept for an idea and am not very knowledgeable about electronics, frequencies, etc... Basically, I just need to know if someone has bumped into a box and then send me an alert that the sensor detected the vibration. I'm not knowledgeable enough about the frequencies and accelerations to really answer the question.
- sensitivity ranges
For this, while it would be nice to have several settings to choose from, I think if it will be easier to just have one setting it would be something that can pick up the vibration as if a 10 lb. puppy bumped into a box on the floor and gently moved the box. But ideally, having a couple sensitivity settings would be better.
- acceptable battery weight and lifetime if, as your need for wireless suggests, it will have to be battery powered.
Definitely lightweight, maybe 3 month runtime, rechargeable or replaceable to be determined. But for the sake of this project, lightweight is preferable.
- if the link between phone and sensor is local (a few dozen meters wifi directly between phone and sensor) or you need to get notified/updated when you are away at the mall.
Would prefer to be notified when away at the mall, etc... thru some type of notification. Could be within the app or a text message or email. But I don't want it to have to use an additional hub to send that information. Kind of like how a Ring doorbell will send you an alert if it detects someone at your door.
I would rather build the sensor itself as "raw" as possible - just forward vibration data stream and chose on the phone application what to do with the stream - set event on/off vibration level thresholds, "pause" by ignoring data two minutes after an event, chose when to notify the user, etc..
Raw is fine. I need to attach it to the side of a box but other than that it doesn't matter how refined it is. Forwarding and choosing what to do in the app is great.
Blimpyway, I hope this helps, again, I am not very knowledgeable in these areas and am learning as I go. If this is something you think can be done, please let me know or private message me so we can discuss next steps, time frames, costs, etc... Thank you!
