Looking to hire someone to write a sketch
Hello,
I'm looking to hire someone to write a basic sketch for me. I really don't have the time, nor the interest to do it myself. I will be using a Micro, as I already have a couple of them here. I will need (3) digital inputs setup with pulldowns and (1) PWM output set to operate at 100hz. The inputs will be connected to normally open switches that are all fed with VCC. The state of these 3 inputs shall determine the pulse width of the output. Only one switch shall be closed at a time. Operation shall be as follows:
No inputs high = 100% duty cycle
Input 1 high = 70% duty cycle
Input 2 high = 50% duty cycle
Input 3 high = 20% duty cycle
Not quite sure how this "for hire" thing works. Guess we'll just take it one step at a time. Thanks
PM sent.
Is your circuit already built? It would be much easier to get rid of the pull down resistors and tie the other side of you switches to ground rather than VCC. Less external components. LOW == pressed, HIGH == not pressed.
Job is completed and paid. Thank you.
