Hi all,
I wanted to give you a heads up about an e-book I just released called Connecting Arduino: Programming and Networking with the Ethernet Shield.
The idea behind this was born out of my frustrations of trying to get Ethernet Shield based projects to work but not finding the right resources to make it happen. A lot of self learning and research solving my own problems left me with enough info I figured I could wrap up to help out other programmers in the same position.
The book is designed to really explore not only the Ethernet Shield and its library classes, but go further into application protocols and what it really means for devices to connect to each other.
You can check it out on Kindle or Google Play. It's priced at just $0.99 for now (GP price should update soon) because I'd like to see as many people get use out of it as possible. I'm happy to answer any questions here about whats in it!
Full book description below:
The Arduino Ethernet Shield is a powerful device for connecting Arduinos to local area networks and to the Internet. But despite its popularity, few authors have attempted to explain how to use this shield to its full potential – leaving new users and less-experienced programmers to piece together fragments of information.
In Connecting Arduino, Bob Hammell guides the reader through the processes and key concepts involved in writing projects that use the Ethernet Shield. More than just a recipe book, this in-depth series of tutorials explores all aspects of the Ethernet library, and discusses how to work with Internet protocols such as HTTP and DNS. You don’t need a computer science degree to understand it, only a basic knowledge of how to write Arduino sketches.
Using clear, easy-to-follow examples, you will learn how to:
- Connect your Arduino to your network router
- Work with the SD card reader built-in to the Ethernet Shield
- Download files and webpages from the Internet to your Arduino
- Serve files and make the information contained in a sketch available to the world
- Create a web-based user interface and API to control your projects
- Build a local DNS server
- Design and implement application protocols for Internet and network communication
This is the definitive guide to the Arduino Ethernet Shield – the documentation everyone else wishes they’d had; the best starting point for creating standalone, Internet-enabled devices; and your gateway to the Internet of Things.
