AndreK
December 15, 2015, 10:45am
1
I wish to replace some data with text:
if uint16_t is 267 then make a="some text"
The thing is that there is that the numbers+strings are not consecutive.
not like
1="stringone"
2="anotherstring"
it's more like:
4="astring"
76="something else"
433="more"
I'd like to avoid an crazy-big switch and case...
system
December 15, 2015, 11:21am
2
Then an array of numbers and an array of strings is in order. Use a for loop to iterate over the array of numbers. If the number in the array is the number of interest, the same index can be used to access the correct data from the string array.
AndreK:
extending @PaulS 's comments, you could use a struct to organize your data:
struct myStruct{
int myNumber;
char* myText;
const myStruct myArray[] = {
{4, "astring"},
{76, "something else"},
{433, "more"}
int myValue = 76;
for(int i = 0; i < sizeof(myArray)/sizeof(myArray[0]); i++)
if (myArray[i].myNumber == myValue)
Serial.println(myArray[i].myText);
AndreK
December 15, 2015, 12:51pm
5
@BulldogLowell - thank you, the example is very informative.
