loop 4 times panobot
I am new to programming and trying to figure out how to stop a loop after executed 4 times.
I am working on a panobot (motorized panoramic head). What the code does is rotate a steppermotor 90 degrees and take a photo. After 4 90 degree rotations and photographs i want it to stop. I do not know how to achieve that.
This is the code i have so far:
#define SHUTTER_PIN 7
int Distance = 0;  // Record the number of steps we've taken
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  digitalWrite(8, LOW);
  digitalWrite(9, LOW);
  digitalWrite(9, HIGH);
  delayMicroseconds(60);
  Distance = Distance + 1;   // record this step
  // Check to see if we are at the end of our move
if (Distance == 21481)   //  (stepper with 26,8:1 gearbox and microstepper shield (1:16)
    Distance = 0;
    // Now pause for a second
    digitalWrite(SHUTTER_PIN, LOW);
    delay(2000);  // take schot
    digitalWrite(SHUTTER_PIN, HIGH);
have a look at the for loop - http://www.arduino.cc/en/Reference/For -
or something like this
int maxshots = 4;
int shots = 0;
  if (shots < maxshots)
    rotate(90);
    take_shot();
    shots = shots + 1;   // or shots++;  in short
  // do other things here
void rotate(int degrees)
  ... // rotate code
void take_shot()
  .. here the code to take a shot
Dag Rob,
I changed the code but the stepper isn’t moving… Am i missing something?
#define STEPPER_PIN 8
int maxshots = 4;
int shots = 0;
  pinMode(9, OUTPUT);
    rotate();
void rotate()
  digitalWrite(STEPPER_PIN, HIGH);
  digitalWrite(STEPPER_PIN, LOW);
  if (Distance == 21481)  // 4 fotos per omwenteling
    Distance = 0;
    delay(2000);  // lengte schots
How is your stepper motor connected to the Arduino? Why are you not using the Stepper library?
Holding a pin HIGH or LOW like that looks weird.
I changed the code but the stepper isn't moving.. Am i missing something?
Yes, you are. Debug statements.
The stepper is connected to a big easy stepper shield. I am just starting with arduino and electronics, so everything is new to me..
For this moment the stepper is working, but it keeps going on (rotate 90 degr. take a picture, rotates, picture..) until i disconnect the power. What i wand is that it stops after 4 movements of 90 degrees and 4 pictures. Next step is a better code and more features.. I am learning.. :wink:
No. The next step is to learn to use Serial.begin(), Serial.print(), and Serial.println() to debug your program.
Oké, you're right. But can you put me in the right direction to achieve where I'm asking for with some modifications on the code i have?
No, I can't. I can't see anything wrong with it. I'd start with some debugging, to determine if rotate() is called at all. If not, you have one problem. If it is, you have another.
When i remove: shots = shots + 1; it works, but of course it will not stop after 4 times.
Your control logic does not make sense.
In loop() you will call rotate() four times and then stop calling it. In rotate you step the motor one position and check whether the total number of steps has reached 21481. (Of course it hasn’t - it will never get past four.)
You need to decide whether you’re going to have rotate move the stepper to the required position and return when the movement is completed, or call it repeatedly until the movement is completed (in which case you need to provide some way for loop() to determine when the movement is completed).
If this is all your sketch ever needs to do, then the simplest approach would be along these lines (pseudocode):
for(int shot = 0; shot < TotalShots; shot++)
    for(int step = 0; step < StepsPerShot; step++)
        stuff to make the stepper move one step
    stuff to take a shot
while(true) {} // execution does not proceed past this point
Thanks for the help! it works. The Serial.println tip was also very useful.
#define DIRECTION_PIN 8
#define STEPPER_PIN 9
int TotalShots = 4;
long StepsPerShot = 85924 / TotalShots; // 85924 is the total amound of steps te complete a rotation (200 x 26,7:1 planetgear x 16 microsteps)
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  Serial.println(StepsPerShot);
void loop()  {
    for(int steps = 0; steps < StepsPerShot; steps++)
      delayMicroseconds(60); // speed of the stepper
    delay(2000);  // take shot
it works.
So now we are curious for the photos
just kidding :wink:
see www.hanshermans.nl :wink:
still a long way to go to complete the panobot..
