Loop and if question.
I'm trying to control a RGB led and have it change color 1 time every 3 seconds. But because of the delay in the loop it will create a gap in witch it will not be able to read my sensors. In this case it's extremely important the sensors can be read within a few milliseconds.
int PIN_RED    = 9;
int PIN_GREEN  = 10;
int PIN_BLUE   = 11;
int motor  = [4,5];   //4 backward, 5 forward
int tButton= 2;       //tells motor to stop then go backward
int bButton= 3;       //tells motor to stop then go forward
//Colors
#define BLACK           B000
#define RED             B001
#define GREEN           B010
#define YELLOW          B011
#define BLUE            B100
#define MAGENTA         B101
#define CYAN            B110
#define WHITE           B111
#define WAIT            1000    // 1000ms (1s) delay
byte pattern[] = {
  RED, YELLOW, GREEN, CYAN, BLUE, MAGENTA
void color(byte v)
  digitalWrite(PIN_RED,    v       & 0x01); // write current values to LED pins
  digitalWrite(PIN_GREEN, (v >> 1) & 0x01);
  digitalWrite(PIN_BLUE,  (v >> 2) & 0x01);
  pinMode(PIN_RED,   OUTPUT);   // sets the RGB pins as output
  pinMode(PIN_GREEN, OUTPUT);
  pinMode(PIN_BLUE,  OUTPUT);
  pinMode(motor, OUTPUT);
  pinMode(tButton,INPUT);
  pinMode(bButton,INPUT);
// Main program
  for (byte i = 0; i < 6; i++) {
    color(pattern[i]);
    delay(3000);     // this is where i need to be able to read 1 of the 3 touch sensors I will have.
that delay is my problem is there a way i can still let the if statements run , while that delay is still going? because that delay will make up a big majority of the loop.
Look at the "Blink without Delay" example; its basically what you need to do:
:slight_smile:
Thanks, I hope I can figure out how to integrate that. haha ::slight_smile:
Bump*
How's this i had my friend help me.
int PIN_RED    = 9;
    int PIN_GREEN  = 10;
    int PIN_BLUE   = 11;
    int counter= 0;
    int animationDelay = 200;
    int Motor  = [4,5];  //4 backward, 5 forward
    int Button1= 2;       //tells motor to stop then go backward.
    int Button2= 3;       //tells motor to stop activated by chain dog.
    int Button3= 6;       //tells motor to run forward (activated by car)
    // Matt -- My added in variable declariations
    long savmill = 0
    byte state = 0
    //Colors
    #define BLACK           B000
    #define RED             B001
    #define GREEN           B010
    #define YELLOW          B011
    #define BLUE            B100
    #define CYAN            B110
    #define WHITE           B111
    byte pattern[] = {
    void color(byte v)
      pinMode(Motor,[4,5] OUTPUT); //4 is backward 5 is forward
      pinMode(Button1 ,    INPUT);
      pinMode(Button2 ,    INPUT);
      pinMode(Button3 ,    INPUT);
      savmill = millis();
    // Main program
      unsigned long curmill = millis();
      if (curmill - savmill > WAIT) {
          savmill = curmill;
          state = (state MOD 6) + 1;
          color(pattern[state]);
      if Button3 = (HIGH){  // runs motor
         Motor ,5 = (HIGH);
        if (Button1=(HIGH){ // stops motor
          Motor , 5 =(LOW
          Curmil - savmill > WAIT) // delays the motor without stopping the RGB code.
          Motor , 4= (HIGH)
          if Button2=(HIGH){// stops motor until being reactivated.
            (motor , 4 (LOW))
         Motor ,5 = (HIGH);
Time to get another friend.
By now, you've found that this doesn't compile.
if (Button3) { // runs motor
 Motor ,5 = (HIGH);
Not sure what that's supposed to do,
if (Button1=(HIGH){ // assigns HIGH to Button1 and evaluates to "true" (or at least it would if it had another parenthesis)
Why don't you take the time to work through some of the examples, learn the language and then come back?
Does it compile?
Once you get over the learning hump for variables and the like and come back to this problem, you may consider using a timer process to read the sensor and update global variables. You can then use those variables in your loop without a worry about delay time.
See this link.
http://www.arduino.cc/playground/Code/Timer1
See the code at the bottom and notice the callback function. In that callback function you can read your sensor / buttons and set variables as needed. This frees up your loop to do whatever "primary" processing needed.
You may want to start with that code, have it read a button state and set a variable accordingly. You can then, in the loop, turn set the LED status (on/off) based on that variable. That may be a good start to accomplishing the desired task and provide an easier ramp up as far as that debugging is required. First get your button pressing / sensor reading code working before you attempt to integrate it into a larger or existing process.
Some working code (old and untested,uses Timer 2, but should work)
//Find timer at http://www.arduino.cc/playground/Main/MsTimer2
#include <MsTimer2.h>
//--- Button Pin
#define BUTTON 7
//--- used to store old value
int  old_val=0;
unsigned long time=0;
boolean buttonPressNew = false;
void checkButton(){
  //IMPORTANT: NO DELAY OR LONG ACTION HERE .. just change button status and take action in the loop
  //-- no need for val to be global .. just takes up 2 bytes for nothing being global.
  int val = digitalRead(BUTTON);
  //-- If they are not the same then ...
  if( val != old_val ){
    //-- Reset last value
    old_val = val;
    //-- If value is turned on .. then we need to tell the system it was hit once ..
    //   but not do it over and over until released
    if( val ){
      buttonPressNew = true;
  //--- Starndard Setup
  pinMode(BUTTON,INPUT);
  //--- Initialize timer2 .. using 20ms for this example
  MsTimer2::set(20, checkButton);
  MsTimer2::start();
  //Do any normal processing here ... it can run as long as you like and not effect the reading of the button.
  //Simple Example ... a delay .. this will only process a single button click.
  // so in this example .. if the button is pressed twice in this delay period .. it picks up only one time.
  // if the button check was in the loop .. it would not see the button at all.
  // if multiple button presses being excepted while in this delay .. and the action is quick .. it can be run in the loop
  //   or a counter added
  delay(5000);
  // This flag is set when a button is pressed .. take action in the loop and reset
  if( buttonPressNew ){
    // Take action based on the button being pressed...
    // then reset
    //IMPORTANT: Notice serial printing done here .. not in timer process
    Serial.println("Button Was Pressed");
Good luck and have fun.
(motor , 4 (LOW))
btw, what language is this?
Got my other friend to help me, thanks AWOL.
 //Jeromy's universal Cable lift.
/* You need 3 momentary switches a ss car can easily press and an H bridge taht can run a knex/custom motor*/
    int PIN_RED    = 9;
    int PIN_GREEN  = 10;
    int PIN_BLUE   = 11;
    int counter= 0;
    int motorForward = 4;
    int motorBackward = 5;
    long savmill = 0
    byte state = 0
    //Colors
    #define BLACK           B000
    #define RED             B001
    #define GREEN           B010
    #define YELLOW          B011
    #define BLUE            B100
    #define CYAN            B110
    #define WHITE           B111
    #define WAIT_LED            6000    // 5000ms (10s) delay
    byte pattern[] = {
    void color(byte v)
      pinMode( motorForward, OUTPUT );
      pinMode( motorBackward, OUTPUT );
      savmill = millis();
    // Main program
      if (curmill - savmill > WAIT_LED) {
          savmill = curmill;
     switch(motorState)
          switch(motorState)
        case STATE_NOTHING:
          if (button1 == HIGH)
            motorState = STATE_FORWARD;
            motorForward = HIGH;
        case STATE_FORWARD:
          if (button2 == HIGH)
            motorState = STATE_WAITING;
            motorForward = LOW;
            time_start = millis();
        case STATE_WAITING:
          time_now = millis();
          if ( time_now - time_start >= WAIT_MOTOR )
            motorState = STATE_BACKWARD;
            motorBackward = HIGH;
        case STATE_BACKWARD:
          if ( button3 == HIGH )
            motorState = STATE_NOTHING;
            motorBackward = LOW;
Thanks a lot marklar.
