Hello I am looking for some assistance with a program I wrote that runs a random relay trigger within an If Statement based on a button press and timeout delay. I believe I might need to use a While instead of an IF statement and possibly a software debounce. I am however extremely new to arduino and my Google skills are failing me this evening.
My main issue in my code below is with function "void operateRelay8()"
int relay1 = 0; //Vibration
int relay2 = 1; //Sander
int relay3 = 2;
int relay4 = 3;
int relay5 = 4;
int relay6 = 5;
int relay7 = 6;
int relay8 = 7; //Edison Bulb
byte switchVal = LOW;
const int buttonPin = 12; //the number of the pushbutton
const int ledPin = 13;
#define RELAY_ON LOW
#define RELAY_OFF HIGH
unsigned long relayDuration = 10000;
unsigned long relaystartmillis = 0;
unsigned long relay8startmillis = 0;
long randOn = 0; // Initialize a variable for the ON time
long randOff = 0; // Initialize a variable for the OFF time
int relay1State = RELAY_OFF;
int relay2State = RELAY_OFF;
int relay3State = RELAY_OFF;
int relay4State = RELAY_OFF;
int relay5State = RELAY_OFF;
int relay6State = RELAY_OFF;
int relay7State = RELAY_OFF;
int relay8State = RELAY_ON;
pinMode (0, OUTPUT);
pinMode (1, OUTPUT);
pinMode (2, OUTPUT);
pinMode (3, OUTPUT);
pinMode (4, OUTPUT);
pinMode (5, OUTPUT);
pinMode (6, OUTPUT);
pinMode (7, OUTPUT);
pinMode(ledPin, OUTPUT);
pinMode(buttonPin, INPUT);
randomSeed (analogRead (0)); // randomize
readPin();
operateRelay();
operateRelay8();
digitalWrite(relay4, RELAY_OFF);
digitalWrite(relay5, RELAY_OFF);
digitalWrite(relay6, RELAY_OFF);
digitalWrite(relay7, RELAY_OFF);
void readPin () {
switchVal = digitalRead(buttonPin);
void operateRelay() {
if (relay2State == RELAY_OFF) {
if (switchVal == HIGH) {
relaystartmillis = millis();
digitalWrite(relay1, RELAY_ON);
relay2State = RELAY_ON;
digitalWrite(relay2, RELAY_ON);
relay1State = RELAY_ON;
} else { //this happens if relayState2 == RELAY_ON
if (millis() - relaystartmillis >= relayDuration) { //time has expired
digitalWrite(relay2, RELAY_OFF);
digitalWrite(relay1, RELAY_OFF);
void operateRelay8() {
randOn = random (100, 1200); // generate ON time between 0.1 and 1.2 seconds
randOff = random (200, 900); // generate OFF time between 0.2 and 0.9 seconds
if (relay8State == RELAY_ON) {
relay8startmillis = millis();
digitalWrite(relay8, RELAY_OFF); // sets the LED off
delay(randOff); // waits for a random time while OFF
digitalWrite(relay8, RELAY_ON); // sets the LED on
delay(randOn); // waits for a random time while ON
if (millis() - relay8startmillis >= relayDuration) {
Making use of delay in code that makes use if millis() based timing does not make sense.
From your code, I can not determine what you exactly want to achieve. While the button is pressed, the relay8 must toggle with random delays and it stops when the button is released?
Just a note at the side:
unless randOn and randOff are used in other functions as well, they should not have global scope. They should have local scope to the operateRelay8 function (and probably be static).
Thank you both for your replies. What I am trying to accomplish is when the button is pressed, turn relay on/off at random times until I delayed amount of time becomes true, then leave the relay in the on position.
I have utilized the internal Pull Up resistor, which has fixed the sporadic issues I was getting, However the relay8 code doesn't loop until delayed time value is reached. It will only loop through the random sequence when the button is held down.
I think you want something like the following. Since you are using delays while waiting for the time to pass, the actual duration will be greater than the variable relayDuration, adding to the randomness.
// if relay is on
// if switch was read high
// mark start
// while duration has not passed
while (millis() - relay8startmillis <= relayDuration)
// get random on/off times
// turn relay off and on
One problem I see is that you never change the relay8State in the function. The below code toggles the relay while the button iis pushed with variable durations and switches it on when the button is released.
// delay duration for on or off
static unsigned long delayDuration;
// if button pressed
// if delay not started yet
if (relay8startmillis == 0)
// toggle relay state
relay8State = !relay8State;
// set delay start time
// set the delay depending on the relay state
delayDuration = random (100, 1200); // set on time
delayDuration = random (200, 900); // set off time
// set the relay according to the relay state
digitalWrite(relay8, relay8State);
// if time lapsed
if(millis() - relay8startmillis >= delayDuration)
// reset the start time
// set the relay state to on
// indicate no delay in progress
It’s non-blocking so you have to keep calling it from loop (as you already do).
not sure how long you awnt to be turning the relay on and off for.
Thank you Blue Eyes your code worked exactly how I envisioned it when I started this project. Here is the final code incase anyone in the future needs something like this:
// Halloween Electric Chair Prop, Version 11.2
// Created by: Cleight, 2016
int relay2 = 1; //Strobe
int relay3 = 2;
int relay4 = 3;
int relay5 = 4;
int relay6 = 5;
int relay7 = 6;
byte switchVal = HIGH;
unsigned long relayDuration = 75000;
pinMode(buttonPin, INPUT_PULLUP);
readPin();
operateRelay();
operateRelay8();
digitalWrite(relay3, RELAY_OFF);
void readPin () {
if (switchVal == LOW) {
// if relay is on
// mark start
randOn = random (100, 1000); // generate ON time between 0.1 and 1.2 seconds
randOff = random (200, 800); // generate OFF time between 0.2 and 0.9 seconds
