I have an esp32, pn532 NFC, and an i2c oled display.
I have a problem where the button press is not being detected unless I tap the NFC reader. I highly suspect its somehow getting stuck somewhere in void loop. but i have no idea where..
In the loop if i disable checkNfcTag() the button then gets detected
So something in this section of code is causing the loop to get stuck...
any advice appreciated
void checkNfcTag() {
uint8_t success;
uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 }; // Buffer to store the returned UID
uint8_t uidLength;
// Wait for an NFC card
success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
if (success) {
// Display the UID to the serial monitor
Serial.print("Found an NFC tag with UID: ");
for (uint8_t i = 0; i < uidLength; i++) {
Serial.print(uid[i], HEX);
Serial.print(" ");
nfc.SAMConfig(); // Reinitialize the NFC reader for the next scan
// Handle the NFC tag event
// handleNfc();
full code below
#include <WiFi.h>
#include <HTTPClient.h>
#include <U8g2lib.h>
#include <Wire.h>
#include <Adafruit_PN532.h>
// Initialize U8g2 for SH1106 display using I2C
U8G2_SH1106_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE, /* clock=*/ SCL, /* data=*/ SDA);
// PN532 pins
#define PN532_SCK (18)
#define PN532_MOSI (23)
#define PN532_SS (5)
#define PN532_MISO (19)
#define PIN 15
#define NUMPIXELS 24
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
// Initialize the PN532 module
Adafruit_PN532 nfc(PN532_SS);
// Wi-Fi credentials
const char* ssid = "wifi2g"; // Your Wi-Fi SSID
const char* password = "qwerty12"; // Your Wi-Fi Password
// URL for retrieving wait times for user1
const char* url = "https://www.magicwaits.com/WebViewer/WaitTime.php?username=user1";
// Button pin
const int buttonPin = 27;
bool buttonPressed = false; // State to track button press
unsigned long lastDebounceTime = 0;
unsigned long debounceDelay = 200; // 200 ms debounce time
unsigned long lastSerialOutputTime = 0; // Time to track 5-second intervals
// Variables to store ride data
String rideNames[20]; // Array to store ride names
String waitTimes[20]; // Array to store wait times
int totalRides = 0; // Total number of rides
int currentRideIndex = 0; // Index for current ride being displayed
// Additional variables for non-ride data
int daysUntilHoliday = 0;
bool clockMode = false;
bool displayHoliday = false;
// 'Untitled', 127x64px (your splash screen image)
const unsigned char epd_bitmap_Untitled[] PROGMEM = {
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f,
0xff, 0xff, 0x7f, 0xff, 0xfb, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f,
0xff, 0xfb, 0x3f, 0xff, 0xf1, 0x1f, 0xfc, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f,
0xff, 0xf1, 0x3f, 0xfe, 0xf1, 0x07, 0x30, 0xf0, 0x00, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f,
0xff, 0xf1, 0x1f, 0xfe, 0xe0, 0x03, 0x00, 0x30, 0x00, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f,
0xff, 0xe1, 0x1f, 0xfe, 0xe0, 0x01, 0x00, 0x10, 0x00, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f,
0xff, 0xe0, 0x0f, 0x7c, 0xc0, 0x00, 0x00, 0x10, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f,
0xff, 0xc0, 0x07, 0x7c, 0xc0, 0x80, 0x81, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f,
0xff, 0xc0, 0x07, 0x3c, 0x80, 0xe0, 0x73, 0x00, 0xb8, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f,
0x7f, 0x80, 0x03, 0x38, 0x00, 0xe0, 0x9b, 0x00, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f,
0x7f, 0x80, 0x01, 0x18, 0x00, 0x30, 0x00, 0x00, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f,
0x7f, 0x00, 0x01, 0x10, 0x00, 0x30, 0x00, 0x00, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f,
0x3f, 0x00, 0x00, 0x10, 0x04, 0x30, 0x00, 0x00, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f,
0x3f, 0x00, 0x00, 0x00, 0x0e, 0x30, 0x00, 0x00, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f,
0x1f, 0x00, 0x20, 0x00, 0x0e, 0xe0, 0x03, 0x00, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f,
0x1f, 0x08, 0x70, 0x20, 0x02, 0xe0, 0x83, 0x00, 0x38, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f,
0x1f, 0x1c, 0x70, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0xfc, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f,
0x0f, 0x1c, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf8, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f,
0x0f, 0x3c, 0xf8, 0x00, 0x00, 0x00, 0x20, 0x10, 0x00, 0xf8, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f,
0x0f, 0x7c, 0xfc, 0xc0, 0x3f, 0x00, 0x30, 0x30, 0x00, 0xfc, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f,
0x0f, 0x7e, 0xfe, 0xc0, 0x7f, 0x30, 0x18, 0x70, 0x00, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f,
0x7f, 0xfe, 0xfe, 0xe5, 0x7f, 0xfc, 0xbf, 0x3f, 0x83, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x7f,
0xff, 0xff, 0xff, 0xff, 0xff, 0xcf, 0x3f, 0x3e, 0xff, 0x07, 0x00, 0x0c, 0xfc, 0xff, 0xff, 0x7f,
0xff, 0xff, 0xff, 0xff, 0xe3, 0xc7, 0x1f, 0x18, 0x3e, 0x00, 0x00, 0x00, 0xf8, 0xff, 0xff, 0x7f,
0xff, 0xff, 0xff, 0xff, 0xc0, 0x87, 0x1f, 0x18, 0x3e, 0x00, 0x00, 0x00, 0xfc, 0xff, 0xff, 0x7f,
0xff, 0xff, 0xff, 0xff, 0xc0, 0x87, 0x0f, 0x08, 0x3c, 0x00, 0x00, 0x00, 0xfc, 0xff, 0xff, 0x7f,
0xff, 0xff, 0xff, 0xff, 0xc1, 0x03, 0x0f, 0x08, 0x3c, 0x10, 0x00, 0x04, 0xfe, 0xff, 0xff, 0x7f,
0xff, 0xff, 0xff, 0xff, 0x81, 0x03, 0x07, 0x04, 0x38, 0x70, 0x00, 0xf4, 0xff, 0xff, 0xff, 0x7f,
0xff, 0xff, 0xff, 0xff, 0x81, 0x01, 0x06, 0x06, 0x38, 0x70, 0x60, 0xf0, 0xff, 0xff, 0xff, 0x7f,
0xff, 0xff, 0xff, 0xff, 0x03, 0x01, 0x02, 0x02, 0x30, 0x70, 0x60, 0xe0, 0xff, 0xff, 0xff, 0x7f,
0xff, 0xff, 0xff, 0xff, 0x03, 0x00, 0x00, 0x03, 0x30, 0x70, 0x60, 0x00, 0xfe, 0xff, 0xff, 0x7f,
0xff, 0xff, 0xff, 0xff, 0x07, 0x00, 0x00, 0x01, 0x20, 0x70, 0xf0, 0x00, 0xf8, 0xff, 0xff, 0x7f,
0xff, 0xff, 0xff, 0xff, 0x07, 0x00, 0x80, 0xc1, 0x00, 0x70, 0xf0, 0x01, 0xf0, 0xff, 0xff, 0x7f,
0xff, 0xff, 0xff, 0xff, 0x0f, 0x10, 0x80, 0xc0, 0x40, 0x30, 0xf0, 0x07, 0xf0, 0xff, 0xff, 0x7f,
0xff, 0xff, 0xff, 0xff, 0x0f, 0x30, 0xc0, 0xe0, 0x01, 0x30, 0xf0, 0x3f, 0xe0, 0xff, 0xff, 0x7f,
0xff, 0xff, 0xff, 0xff, 0x1f, 0x38, 0x40, 0x00, 0x00, 0x30, 0xf0, 0x7f, 0xe0, 0xff, 0xff, 0x7f,
0xff, 0xff, 0xff, 0xff, 0x1f, 0x78, 0x20, 0x00, 0x00, 0x30, 0xf0, 0x7d, 0xe0, 0xff, 0xff, 0x7f,
0xff, 0xff, 0xff, 0xff, 0x1f, 0x7c, 0x20, 0x00, 0x00, 0x31, 0xf0, 0x00, 0xf0, 0xff, 0xff, 0x7f,
0xff, 0xff, 0xff, 0xff, 0x3f, 0xfc, 0x10, 0x00, 0x00, 0x10, 0xf0, 0x00, 0xf0, 0xff, 0xff, 0x7f,
0xff, 0xff, 0xff, 0xff, 0x3f, 0xfe, 0x10, 0xf0, 0x07, 0x10, 0x70, 0x00, 0xf0, 0xff, 0xff, 0x7f,
0xff, 0xff, 0xff, 0xff, 0x7f, 0xfe, 0x19, 0xf8, 0x07, 0x12, 0x70, 0x00, 0xf8, 0xff, 0xff, 0x7f,
0xff, 0xff, 0xff, 0xff, 0x7f, 0xff, 0x79, 0xfc, 0x8f, 0xff, 0xf8, 0x01, 0xfe, 0xff, 0xff, 0x7f,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0x7f, 0xfe, 0xcf, 0x7f,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x3f, 0x80, 0x01, 0x7e, 0xfe, 0xcf, 0x7f,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x0f, 0x80, 0x00, 0x78, 0xfc, 0x87, 0x7f,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0x00, 0x00, 0x30, 0xfc, 0x83, 0x7f,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x03, 0x00, 0x00, 0x20, 0xf8, 0x83, 0x7f,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x03, 0x00, 0x00, 0x20, 0xf8, 0x01, 0x7f,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x01, 0x2e, 0x78, 0x00, 0xf0, 0x00, 0x7f,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x81, 0x1f, 0xfc, 0x00, 0xe0, 0x00, 0x7e,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x81, 0x0f, 0xfc, 0x00, 0x60, 0x00, 0x7e,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0x0f, 0xfc, 0x01, 0x00, 0x00, 0x7e,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0x0f, 0xfc, 0x01, 0x00, 0x00, 0x7c,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x81, 0x3f, 0xfc, 0x00, 0x00, 0x00, 0x7c,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x87, 0x81, 0x7f, 0xf8, 0x00, 0x00, 0x08, 0x7c,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0x01, 0x8e, 0x00, 0x20, 0x03, 0x0c, 0x78,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x03, 0x01, 0x00, 0x01, 0x20, 0x07, 0x1c, 0x78,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x03, 0x03, 0x00, 0x02, 0x00, 0x07, 0x1e, 0x78,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x03, 0x07, 0x00, 0x02, 0x08, 0x0f, 0x1f, 0x70,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x03, 0x0f, 0x00, 0x01, 0x84, 0x0f, 0x3f, 0x70,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x87, 0x1f, 0x80, 0x8f, 0x83, 0x9f, 0x3f, 0x78,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe0, 0xff, 0x9f, 0x9f, 0x3f, 0x7f,
// Function to display the bitmap image
void displayImage() {
u8g2.clearBuffer();
u8g2.drawXBMP(0, 0, 127, 64, epd_bitmap_Untitled); // Draw the bitmap
u8g2.sendBuffer();
// Initialize serial, OLED display, and PN532
u8g2.begin();
pinMode(buttonPin, INPUT_PULLUP);
nfc.begin();
uint32_t versiondata = nfc.getFirmwareVersion();
if (!versiondata) {
Serial.println("Didn't find PN53x module");
while (1);
// Configure PN532 to read MiFare cards
nfc.SAMConfig();
// Initialize the button pin
// Start connecting to Wi-Fi
WiFi.begin(ssid, password);
// Display the splash screen while connecting to Wi-Fi
unsigned long startTime = millis();
while (millis() - startTime < 10000) { // Display splash for 10 seconds
displayImage(); // Continuously display the splash screen
delay(100); // Short delay to avoid overloading the loop
// Wait for Wi-Fi connection (if not connected yet)
Serial.print(".");
Serial.println("Connected to Wi-Fi");
// Fetch and display data after the splash screen
fetchDataAndStoreRides();
displayRide(currentRideIndex);
// 1. Check the button state first to ensure it works independently of NFC
checkButtonPress();
// 2. Only scan for NFC tag if button is not pressed
if (!buttonPressed) {
static unsigned long lastNfcCheck = 0;
if (millis() - lastNfcCheck >= 500) { // NFC check every 500ms
lastNfcCheck = millis();
//checkNfcTag();
// 3. Periodically update the display (e.g., fetching data every 2 seconds)
static unsigned long lastDisplayUpdate = 0;
if (millis() - lastDisplayUpdate >= 2000) {
lastDisplayUpdate = millis();
displayRide(currentRideIndex); // Update the OLED display periodically
// Non-blocking button press check with debounce
void checkButtonPress() {
int buttonState = digitalRead(buttonPin); // Read button state
if (buttonState == LOW && !buttonPressed && (millis() - lastDebounceTime > debounceDelay)) {
buttonPressed = true; // Mark button as pressed
lastDebounceTime = millis(); // Reset debounce timer
Serial.println("Button Press Detected");
// Action when button is pressed
cycleRides();
if (buttonState == HIGH) {
buttonPressed = false; // Reset button press state when released
// Non-blocking NFC tag detection with timeout to prevent blocking
uint8_t success;
uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 }; // Buffer to store the UID
uint8_t uidLength;
// Use a timeout to ensure NFC polling doesn't block other tasks
uint32_t nfcTimeout = millis() + 50; // NFC timeout of 50ms
while (millis() < nfcTimeout) {
// Attempt to detect an NFC tag (this should not block)
if (success) {
// NFC tag detected, print UID and handle the event
Serial.print(" ");
handleNfc();
break; // Exit after successfully detecting a tag
// Handle NFC actions
void handleNfc() {
// Place NFC-related actions here
Serial.println("NFC DETECTED");
disney();
disneyaccess();
delay(2000);
disneyoff();
void fetchDataAndStoreRides() {
if (WiFi.status() == WL_CONNECTED) {
HTTPClient http;
http.begin(url);
int httpResponseCode = http.GET();
if (httpResponseCode == 200) {
String payload = http.getString();
Serial.println("Full Payload: " + payload); // Output full payload for debugging
// Split the payload by commas
int lastCommaIndex = 0;
int currentCommaIndex = 0;
String parsedData[20]; // Array to store split data (increase size if needed)
int elementCount = 0;
while ((currentCommaIndex = payload.indexOf(',', lastCommaIndex)) != -1) {
parsedData[elementCount++] = payload.substring(lastCommaIndex, currentCommaIndex);
lastCommaIndex = currentCommaIndex + 1;
parsedData[elementCount++] = payload.substring(lastCommaIndex); // Add last part
// Parse the non-ride data (first 6 elements)
daysUntilHoliday = parsedData[0].toInt();
clockMode = parsedData[1].toInt() == 1;
displayHoliday = parsedData[2].toInt() == 1;
String timeZone = parsedData[3];
String holidayDate = parsedData[5];
// Process the rides data (starting from element 6)
totalRides = 0; // Reset total rides count
for (int i = 6; i < elementCount; i++) {
String rideData = parsedData[i];
int colonIndex = rideData.indexOf(':');
rideNames[totalRides] = rideData.substring(0, colonIndex);
waitTimes[totalRides] = rideData.substring(colonIndex + 1);
totalRides++;
Serial.println("Error on HTTP request");
http.end();
// Function to cycle through the rides
void cycleRides() {
currentRideIndex = (currentRideIndex + 1) % totalRides; // Increment the index and wrap around
displayRide(currentRideIndex); // Update the OLED display with the next ride
void disney(){
Serial.print("Disney");
pixels.setPixelColor(23, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(23, pixels.Color(0,0,0));
pixels.setPixelColor(22, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(22, pixels.Color(0,0,0));
pixels.setPixelColor(21, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(21, pixels.Color(0,0,0));
pixels.setPixelColor(20, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(20, pixels.Color(0,0,0));
pixels.setPixelColor(19, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(19, pixels.Color(0,0,0));
pixels.setPixelColor(18, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(18, pixels.Color(0,0,0));
pixels.setPixelColor(17, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(17, pixels.Color(0,0,0));
pixels.setPixelColor(16, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(16, pixels.Color(0,0,0));
pixels.setPixelColor(15, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(15, pixels.Color(0,0,0));
pixels.setPixelColor(14, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(14, pixels.Color(0,0,0));
pixels.setPixelColor(13, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(13, pixels.Color(0,0,0));
pixels.setPixelColor(12, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(12, pixels.Color(0,0,0));
pixels.setPixelColor(11, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(11, pixels.Color(0,0,0));
pixels.setPixelColor(10, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(10, pixels.Color(0,0,0));
pixels.setPixelColor(9, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(9, pixels.Color(0,0,0));
pixels.setPixelColor(8, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(8, pixels.Color(0,0,0));
pixels.setPixelColor(7, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(7, pixels.Color(0,0,0));
pixels.setPixelColor(6, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(6, pixels.Color(0,0,0));
pixels.setPixelColor(5, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(5, pixels.Color(0,0,0));
pixels.setPixelColor(4, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(4, pixels.Color(0,0,0));
pixels.setPixelColor(3, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(3, pixels.Color(0,0,0));
pixels.setPixelColor(2, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(2, pixels.Color(0,0,0));
pixels.setPixelColor(1, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(1, pixels.Color(0,0,0));
pixels.setPixelColor(0, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(0, pixels.Color(0,0,0));
pixels.show();
delay(50);
void disneyaccess()
// player.play(1);
Serial.print("Disney access");
pixels.show();
delay(2000);
disneyoff();
// if(digitalRead(relay) == HIGH)
// digitalWrite(relay,LOW);
// Serial.println("Relay off");
// else
// digitalWrite(relay,HIGH);
// Serial.println("Relay on");
void disneyoff()
Serial.print("Disney off");
pixels.show();
void displayRide(int rideIndex) {
String rideName = rideNames[rideIndex];
String waitTime = waitTimes[rideIndex];
// Clear the display buffer
u8g2.clearBuffer();
// Split the ride name into two lines
int midPoint = rideName.length() / 2;
String line1 = rideName.substring(0, midPoint);
String line2 = rideName.substring(midPoint);
// Set the font and display the first part of the ride name
u8g2.setFont(u8g2_font_ncenB08_tr); // Choose font
int rideWidth1 = u8g2.getStrWidth(line1.c_str());
int rideWidth2 = u8g2.getStrWidth(line2.c_str());
u8g2.drawStr((128 - rideWidth1) / 2, 16, line1.c_str()); // Center the first line
u8g2.drawStr((128 - rideWidth2) / 2, 32, line2.c_str()); // Center the second line
// Display the wait time below the ride name, centered
int waitTimeWidth = u8g2.getStrWidth(waitTime.c_str());
u8g2.drawStr((128 - waitTimeWidth) / 2, 48, waitTime.c_str()); // Center the wait time
// Display the "Disney in X days!" at the bottom, centered
if (displayHoliday) {
String holidayText = "Disney in " + String(daysUntilHoliday) + " days!";
int holidayWidth = u8g2.getStrWidth(holidayText.c_str());
u8g2.setFont(u8g2_font_6x10_tf); // Smaller font for holiday text
u8g2.drawStr((128 - holidayWidth) / 2, 64, holidayText.c_str()); // Center and display at the bottom
// Send all data to the display
u8g2.sendBuffer();
