hello,
I want to make a loop in a function from a remote function.
#include <IRremote.h>
int i = 10;
int RECV_PIN = 6; //ontvangst punt is 11
IRrecv irrecv(RECV_PIN); //library deze pin
decode_results results; //zet om naar getallen
irrecv.enableIRIn(); //setup ontvangst punt
pinMode(i, OUTPUT);
if (irrecv.decode(&results)) { //als een ir signaal is gedetecteerd
long int decCode = results.value; //als het zo is maak er een variabele van
Serial.println(decCode);
irrecv.resume(); // begin opnieuw met zoeken naar ir signaal
switch (results.value) { //afhankelijk van he ir signaal doe dit....
case 16738455://omhoog //kijk of er zo,n signaal komt van de afstandbediening, zo ja doet wat er onder staat
digitalWrite(i, HIGH);
delay(100);
digitalWrite(i, LOW);
delay(100);
break; //niet verder kijken of er nog meer opdrachten zijn voor dit signaal
I want to repeat the
delay(100);
delay(100);
How can I do this?
Use the "BlinkWithoutDelay" example to see how to do a blinking pattern without spending all your processing time in delay(). Then add a variable to enable and disable the blinking code. Then turn that on an off with the remote control input.
How many times? Computers are stupid, you know. They will only do what you tell them to do.
When I use the blinkwithoutdelay it is only runs once, when I press a button on the remote the led goes on and when I press the button again the led goes off. So that doesn't work.
I want the program to run unlimited like the void loop.
ikke1:
You can't. In order to perform more than one task at a time, the loop() function has to be the only loop. You have to use flags, variables and if statements in place of for and while loops (in general).
I found something that does not repeat unlimited but it does repeat much.
for(int i = 0; i<99999999999999999; i++)
But can I use int with such numbers?
ikke1:
The loop() compatible version of that would be:
int i=0;
loop()
if (i<9999)
{ } //stuff that you would do in the for loop here
i++;
No, ints can not store such a big number.
You need to separate reading serial data from using serial data.
if(Serial.available() > 0)
char c = Serial.read();
if(c == 'b')
blink = true;
if(c == 's')
blink = false;
if(blink)
// Use the blink with delay example to determine what to do here
blink would be a boolean variable, with global scope, initialized to false.
