Board Used: Arduino Mega 2560 REV3
PC OS: Windows 10
IDE Version: 1.8.13
Connected via USB
Trying to have the loop() poll serial communications so it knows how to respond when value of 2 or 3 is sent via the Serial Monitor.
#define RelayTop 22
#define RelayBottom 25
//color sensor
#define S0 4
#define S1 5
#define S2 6
#define S3 7
#define sensorOut 8
//motor
#define motor1 53
#define motor2 51
#define motorspeed 49
//G Variables
int frequency = 0;
int color = 0;
int blue = 0;
int incomingByte = 1;
//Begin COM
//Relay Pins
pinMode(RelayTop, OUTPUT);
pinMode(RelayBottom, OUTPUT);
//Color Sensor Pins
pinMode(S0, OUTPUT);
pinMode(S1, OUTPUT);
pinMode(S2, OUTPUT);
pinMode(S3, OUTPUT);
pinMode(sensorOut, INPUT);
//Motor Pins
pinMode(motor1, OUTPUT);
pinMode(motor2, OUTPUT);
pinMode(motorspeed, OUTPUT);
//Setting frequency-scaling to 20%
digitalWrite(S0, HIGH);
digitalWrite(S1, LOW);
//Close Relays
digitalWrite(RelayTop, LOW);
digitalWrite(RelayBottom, LOW);
//Motor Initial
digitalWrite(motor1, LOW);
digitalWrite(motor2, LOW);
digitalWrite(motorspeed, LOW);
delay(150);
// Relay Controls to Dispense ball
void Unload() {
Serial.print("\n UB 2");
digitalWrite(RelayBottom, HIGH);
delay(100);
Serial.print("\n UB 3");
// Relay Controls to Load Ball
void Load() {
Serial.print("\n LB 2");
digitalWrite(RelayTop, HIGH);
delay(100);
Serial.print("\n LB 3");
// Color Sensing
void ColorSensing() {
Serial.print("\n SC 2");
// Setting Blue filtered photodiodes to be read
digitalWrite(S2, LOW);
digitalWrite(S3, HIGH);
blue = pulseIn(sensorOut, LOW);
delay(10);
Serial.print("\n");
Serial.print(blue);
if (blue < 50) {
color = 0;
Serial.print("\n White");
else {
color = 1;
Serial.print("\n Painted");
Serial.print("\n SC 3");
//Motor Turning
void TurnMotor() {
Serial.print("\n TM 2");
if (color == 1) {
digitalWrite(motor1, HIGH);
digitalWrite(motorspeed, HIGH);
delay(30);
delay(25);
if (color == 0) {
digitalWrite(motor2, HIGH);
delay(30);
delay(25);
Serial.print("\n TM 3");
Serial.print("\n Idle");
if (Serial.available() > 0) {
incomingByte = Serial.read();
Serial.print("\n Idle 2 ");
Serial.print("\n ");
Serial.print(incomingByte);
if (incomingByte == 2) {
Serial.print("\n LB1");
Load();
incomingByte = 1;
while (incomingByte == 3) {
Load();
delay(100);
Serial.print("\n CS1");
ColorSensing();
delay(100);
Serial.print("\n TM1");
TurnMotor();
delay(100);
Serial.print("\n UB1");
Unload();
delay(100);
Serial.print("\n Idle 3 ");
The loop enters the first if() statement when prompted and returns the “Idle 2” marker, after that things get weird. When sending a value using the serial monitor, it is being altered. For example, 2=50, 3=51, 4=52. Sending a value of -48 returned 45, then 52, then 56. After the values listed above, it is settles at a value of 10. Here is what the Serial Monitor shows by inputting a value of 2 and then 3.
Idle
Idle 3
incomingByte = 1
Idle
Idle 3
incomingByte = 1
Idle
Idle 2
incomingByte = 50
Idle 3
incomingByte = 50
Idle
Idle 2
incomingByte = 10
Idle 3
incomingByte = 10
Idle
Idle 2
incomingByte = 51
Idle 3
incomingByte = 51
Idle
Idle 2
incomingByte = 10
Idle 3
incomingByte = 10
Any assistance would be greatly appreciated., let me know if I missed any important information.
