#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 20, 4);
int upButton = 10;
int downButton = 11;
int selectButton = 12;
int menu = 1;
lcd.init();
lcd.backlight();
pinMode(upButton, INPUT_PULLUP);
pinMode(downButton, INPUT_PULLUP);
pinMode(selectButton, INPUT_PULLUP);
updateMenu();
if (digitalRead(downButton) == HIGH) {
menu++;
updateMenu();
delay(100);
if (digitalRead(upButton) == HIGH) {
menu--;
updateMenu();
delay(100);
if (digitalRead(selectButton) == HIGH) {
executeAction();
updateMenu();
delay(100);
void updateMenu() {
switch (menu) {
case 0:
menu = 1;
case 1:
menu = 1;
lcd.clear();
lcd.setCursor(0, 0);
lcd.print(">MenuItem1");
lcd.setCursor(0, 1);
lcd.print(" MenuItem2");
lcd.setCursor(0, 2);
lcd.print(" MenuItem3");
lcd.setCursor(0, 3);
lcd.print(" MenuItem4");
case 2:
lcd.clear();
lcd.print(" MenuItem1");
lcd.print(">MenuItem2");
case 3:
lcd.clear();
lcd.print(">MenuItem3");
case 4:
lcd.clear();
lcd.print(">MenuItem4");
case 5:
menu = 4;
void executeAction() {
switch (menu) {
case 1:
action1();
case 2:
action2();
case 3:
action3();
case 4:
action4();
void action1() {
lcd.clear();
lcd.print(">Executing #1");
delay(1500);
void action2() {
lcd.clear();
lcd.print(">Executing #2");
delay(1500);
void action3() {
lcd.clear();
lcd.print(">Executing #3");
delay(1500);
void action4() {
lcd.clear();
lcd.print(">Executing #4");
delay(1500);
My issue seems to be local to.. void(loop)
If I switch up/downButton from HIGH to LOW the menu will scroll straight to the bottom.
If I hit the downButton to lower the menu it only drops once then redraws back to the top.
It seems that the if loop isn't doing exactly what I thought it should.
