#include <avr/sleep.h>
#include <stdint.h>
#include <avr/interrupt.h>
#include <avr/wdt.h>
#include <avrpins.h>
#include <max3421e.h>
#include <usbhost.h>
#include <usb_ch9.h>
#include <Usb.h>
#include <usbhub.h>
#include <avr/pgmspace.h>
#include <address.h>
#include "pgmstrings.h"
int sleepStatus = 0;// variable to store a request for sleep
int count = 0; // counter
int c=0;
int sleepIND=0;
ISR(WDT_vect)
Serial.println("dude we have entered the routine");
c=c+1;
USB Usb;
//USBHub Hub1(&Usb);
//USBHub Hub2(&Usb);
//USBHub Hub3(&Usb);
//USBHub Hub4(&Usb);
//USBHub Hub5(&Usb);
//USBHub Hub6(&Usb);
//USBHub Hub7(&Usb);
uint32_t next_time;
void PrintAllAddresses(UsbDevice *pdev)
UsbDeviceAddress adr;
adr.devAddress = pdev->address;
Serial.print("\r\nAddr:");
Serial.print(adr.devAddress, HEX);
Serial.print("(");
Serial.print(adr.bmHub, HEX);
Serial.print(".");
Serial.print(adr.bmParent, HEX);
Serial.print(".");
Serial.print(adr.bmAddress, HEX);
Serial.println(")");
void PrintAddress(uint8_t addr)
adr.devAddress = addr;
Serial.print("\r\nADDR:\t");
Serial.println(adr.devAddress,HEX);
Serial.print("DEV:\t");
Serial.println(adr.bmAddress,HEX);
Serial.print("PRNT:\t");
Serial.println(adr.bmParent,HEX);
Serial.print("HUB:\t");
Serial.println(adr.bmHub,HEX);
Serial.begin( 115200 );
Serial.println("Start");
if (Usb.Init() == -1)
Serial.println("OSC did not start.");
delay( 200 );
next_time = millis() + 10000;
wdtSetup();
void sleepNow() // here we put the arduino to sleep
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
sleep_enable();
sleep_mode();
sleep_disable();
byte getdevdescr( byte addr, byte &num_conf );
void PrintDescriptors(uint8_t addr)
uint8_t rcode = 0;
byte num_conf = 0;
rcode = getdevdescr( (byte)addr, num_conf );
if( rcode )
printProgStr(Gen_Error_str);
print_hex( rcode, 8 );
Serial.print("\r\n");
for (int i=0; i<num_conf; i++)
rcode = getconfdescr( addr, i ); // get configuration descriptor
if( rcode )
print_hex(rcode, 8);
Serial.println("\r\n");
void PrintAllDescriptors(UsbDevice *pdev)
print_hex(pdev->address, 8);
Serial.println("\r\n--");
PrintDescriptors( pdev->address );
Usb.Task();
if( Usb.getUsbTaskState() == USB_STATE_RUNNING )
//if (millis() >= next_time)
//counter for sleep
sleepIND=1;
Usb.ForEachUsbDevice(&PrintAllDescriptors);
Usb.ForEachUsbDevice(&PrintAllAddresses);
while( 1 );
//stop
USB_DEVICE_DESCRIPTOR buf;
byte rcode;
rcode = Usb.getDevDescr( addr, 0, 0x12, ( uint8_t *)&buf );
if( rcode ) {
return( rcode );
printProgStr(Dev_Header_str);
printProgStr(Dev_Length_str);
print_hex( buf.bLength, 8 );
printProgStr(Dev_Type_str);
print_hex( buf.bDescriptorType, 8 );
printProgStr(Dev_Version_str);
print_hex( buf.bcdUSB, 16 );
printProgStr(Dev_Class_str);
print_hex( buf.bDeviceClass, 8 );
printProgStr(Dev_Subclass_str);
print_hex( buf.bDeviceSubClass, 8 );
printProgStr(Dev_Protocol_str);
print_hex( buf.bDeviceProtocol, 8 );
printProgStr(Dev_Pktsize_str);
print_hex( buf.bMaxPacketSize0, 8 );
printProgStr(Dev_Vendor_str);
print_hex( buf.idVendor, 16 );
printProgStr(Dev_Product_str);
print_hex( buf.idProduct, 16 );
printProgStr(Dev_Revision_str);
print_hex( buf.bcdDevice, 16 );
printProgStr(Dev_Mfg_str);
print_hex( buf.iManufacturer, 8 );
printProgStr(Dev_Prod_str);
print_hex( buf.iProduct, 8 );
printProgStr(Dev_Serial_str);
print_hex( buf.iSerialNumber, 8 );
printProgStr(Dev_Nconf_str);
print_hex( buf.bNumConfigurations, 8 );
num_conf = buf.bNumConfigurations;
return( 0 );
void printhubdescr(uint8_t *descrptr, uint8_t addr)
HubDescriptor *pHub = (HubDescriptor*) descrptr;
uint8_t len = *((uint8_t*)descrptr);
printProgStr(PSTR("\r\n\r\nHub Descriptor:\r\n"));
printProgStr(PSTR("bDescLength:\t\t"));
Serial.println(pHub->bDescLength, HEX);
printProgStr(PSTR("bDescriptorType:\t"));
Serial.println(pHub->bDescriptorType, HEX);
printProgStr(PSTR("bNbrPorts:\t\t"));
Serial.println(pHub->bNbrPorts, HEX);
printProgStr(PSTR("LogPwrSwitchMode:\t"));
Serial.println(pHub->LogPwrSwitchMode, BIN);
printProgStr(PSTR("CompoundDevice:\t\t"));
Serial.println(pHub->CompoundDevice, BIN);
printProgStr(PSTR("OverCurrentProtectMode:\t"));
Serial.println(pHub->OverCurrentProtectMode, BIN);
printProgStr(PSTR("TTThinkTime:\t\t"));
Serial.println(pHub->TTThinkTime, BIN);
printProgStr(PSTR("PortIndicatorsSupported:"));
Serial.println(pHub->PortIndicatorsSupported, BIN);
printProgStr(PSTR("Reserved:\t\t"));
Serial.println(pHub->Reserved, HEX);
printProgStr(PSTR("bPwrOn2PwrGood:\t\t"));
Serial.println(pHub->bPwrOn2PwrGood, HEX);
printProgStr(PSTR("bHubContrCurrent:\t"));
Serial.println(pHub->bHubContrCurrent, HEX);
for (uint8_t i=7; i<len; i++)
print_hex(descrptr[i], 8);
//for (uint8_t i=1; i<=pHub->bNbrPorts; i++)
// PrintHubPortStatus(&Usb, addr, i, 1);
byte getconfdescr( byte addr, byte conf )
uint8_t buf[ BUFSIZE ];
uint8_t* buf_ptr = buf;
byte rcode;
byte descr_length;
byte descr_type;
unsigned int total_length;
rcode = Usb.getConfDescr( addr, 0, 4, conf, buf ); //get total length
LOBYTE( total_length ) = buf[ 2 ];
HIBYTE( total_length ) = buf[ 3 ];
if( total_length > 256 ) { //check if total length is larger than buffer
printProgStr(Conf_Trunc_str);
total_length = 256;
rcode = Usb.getConfDescr( addr, 0, total_length, conf, buf ); //get the whole descriptor
while( buf_ptr < buf + total_length ) { //parsing descriptors
descr_length = *( buf_ptr );
descr_type = *( buf_ptr + 1 );
switch( descr_type ) {
case( USB_DESCRIPTOR_CONFIGURATION ):
printconfdescr( buf_ptr );
case( USB_DESCRIPTOR_INTERFACE ):
printintfdescr( buf_ptr );
case( USB_DESCRIPTOR_ENDPOINT ):
printepdescr( buf_ptr );
case 0x29:
printhubdescr( buf_ptr, addr );
default:
printunkdescr( buf_ptr );
}//switch( descr_type
buf_ptr = ( buf_ptr + descr_length ); //advance buffer pointer
}//while( buf_ptr <=...
return( 0 );
Moderator edit: Try it with
tags next time, please.
