Loop not repeating in execution
/* prints hex numbers with leading zeroes */
// copyright, Peter H Anderson, Baltimore, MD, Nov, '07
// source: http://www.phanderson.com/arduino/arduino_display.html
void print_hex(int v, int num_places)
  int mask=0, n, num_nibbles, digit;
  for (n=1; n<=num_places; n++) {
    mask = (mask << 1) | 0x0001;
  v = v & mask; // truncate v to specified number of places
  num_nibbles = num_places / 4;
  if ((num_places % 4) != 0) {
    ++num_nibbles;
  do {
    digit = ((v >> (num_nibbles-1) * 4)) & 0x0f;
    Serial.print(digit, HEX);
  while(--num_nibbles);
/* function to print configuration descriptor */
void printconfdescr( uint8_t* descr_ptr )
 USB_CONFIGURATION_DESCRIPTOR* conf_ptr = ( USB_CONFIGURATION_DESCRIPTOR* )descr_ptr;
  printProgStr(Conf_Header_str);
  printProgStr(Conf_Totlen_str);
  print_hex( conf_ptr->wTotalLength, 16 );
  printProgStr(Conf_Nint_str);
  print_hex( conf_ptr->bNumInterfaces, 8 );
  printProgStr(Conf_Value_str);
  print_hex( conf_ptr->bConfigurationValue, 8 );
  printProgStr(Conf_String_str);
  print_hex( conf_ptr->iConfiguration, 8 );
  printProgStr(Conf_Attr_str);
  print_hex( conf_ptr->bmAttributes, 8 );
  printProgStr(Conf_Pwr_str);
  print_hex( conf_ptr->bMaxPower, 8 );
  return;
/* function to print interface descriptor */
void printintfdescr( uint8_t* descr_ptr )
 USB_INTERFACE_DESCRIPTOR* intf_ptr = ( USB_INTERFACE_DESCRIPTOR* )descr_ptr;
  printProgStr(Int_Header_str);
  printProgStr(Int_Number_str);
  print_hex( intf_ptr->bInterfaceNumber, 8 );
  printProgStr(Int_Alt_str);
  print_hex( intf_ptr->bAlternateSetting, 8 );
  printProgStr(Int_Endpoints_str);
  print_hex( intf_ptr->bNumEndpoints, 8 );
  printProgStr(Int_Class_str);
  print_hex( intf_ptr->bInterfaceClass, 8 );
  printProgStr(Int_Subclass_str);
  print_hex( intf_ptr->bInterfaceSubClass, 8 );
  printProgStr(Int_Protocol_str);
  print_hex( intf_ptr->bInterfaceProtocol, 8 );
  printProgStr(Int_String_str);
  print_hex( intf_ptr->iInterface, 8 );
  return;
/* function to print endpoint descriptor */
void printepdescr( uint8_t* descr_ptr )
 USB_ENDPOINT_DESCRIPTOR* ep_ptr = ( USB_ENDPOINT_DESCRIPTOR* )descr_ptr;
  printProgStr(End_Header_str);
  printProgStr(End_Address_str);
  print_hex( ep_ptr->bEndpointAddress, 8 );
  printProgStr(End_Attr_str);
  print_hex( ep_ptr->bmAttributes, 8 );
  printProgStr(End_Pktsize_str);
  print_hex( ep_ptr->wMaxPacketSize, 16 );
  printProgStr(End_Interval_str);
  print_hex( ep_ptr->bInterval, 8 );
  return;
/*function to print unknown descriptor */
void printunkdescr( uint8_t* descr_ptr )
  byte length = *descr_ptr;
  byte i;
  printProgStr(Unk_Header_str);
  printProgStr(Unk_Length_str);
  print_hex( *descr_ptr, 8 );
  printProgStr(Unk_Type_str);
  print_hex( *(descr_ptr + 1 ), 8 );
  printProgStr(Unk_Contents_str);
  descr_ptr += 2;
  for( i = 0; i < length; i++ ) {
    descr_ptr++;
/* Print a string from Program Memory directly to save RAM */
void printProgStr(const prog_char str[])
  char c;
  if(!str) return;
  while((c = pgm_read_byte(str++)))
    Serial.print(c);
void wdtSetup() {
  cli();
  MCUSR = 0;
  WDTCSR |= B00011000;
  WDTCSR = B01100001;
  sei();
Moderator edit: And again.
