Loop only Switch Change
I have an Arduino Uno Rev 3 with Ethernet Shield. My goal is when a smoke detector goes off (cannot remember if it is NO or NC) the board will send an email (which will be changed to email to text). I have found the code below online and it works well, except I cannot get it to run only on the switch status change. I have tried to insert parts of the state change example code into this one but I cannot get it to work. (depending on where the parts of code are inserted it either doesn't work at all (rapid email's being sent, connection failure, or timeout failure). I am very new to Arduinos and would appreciate any advice you can give.
Thanks,
Craig
Tihomir Nedev
April 2014
Change the values for the network setting.
Change the emails. NB! Some sorvers won't accept email for unedentified devices as Arduino.
Hardware: Arduino board + Ethernet shield
#include <SPI.h>
#include <Ethernet.h>
// Set the panic button pin
byte panicButton = 2;
boolean statusCheck=false;
// this must be unique
byte mac[] = { 0xA8, 0x61, 0x0A, 0xAE, 0x6B, 0x55 };
// change network settings to yours
IPAddress ip(192,168,1,19);
IPAddress gateway(192,168,1,1);
IPAddress subnet(255,255,255,0);
// change server to your email server ip or domain
// IPAddress server( 1, 2, 3, 4 );
char server[] = "mail.bresnan.net";
EthernetClient client;
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  delay(2000);
  Serial.println(F("Ready."));
  pinMode(panicButton, INPUT);
  if(digitalRead(panicButton)==HIGH && statusCheck==false)
      if(sendEmail()) Serial.println(F("Email sent"));
      else Serial.println(F("Email failed"));
    statusCheck = true;
  else if (digitalRead(panicButton)==LOW)
  statusCheck = false;
byte sendEmail()
  byte thisByte = 0;
  byte respCode;
  if(client.connect(server,25)) {
    Serial.println(F("connected"));
    Serial.println(F("connection failed"));
    return 0;
  if(!eRcv()) return 0;
// change to your public ip
  client.println(F("helo 1.2.3.4"));
  Serial.println(F("Sending From"));
// change to your email address (sender)
  client.println(F("MAIL From: xxx@xxxx.net"));
// change to recipient address
  Serial.println(F("Sending To"));
  client.println(F("RCPT To: xxxx@gmail.com"));
  Serial.println(F("Sending DATA"));
  client.println(F("DATA"));
  Serial.println(F("Sending email"));
  client.println(F("To: xxxx@gmail.com"));
// change to your address
  client.println(F("From: xxxx@xxxx.net"));
  client.println(F("Subject: Barn Smoke Alarm!\r\n"));
  client.println(F("The Barn Smoke Alarm is Active!!!"));
  client.println(F("."));
  Serial.println(F("Sending QUIT"));
  client.println(F("QUIT"));
  client.stop();
  Serial.println(F("disconnected"));
  return 1;
byte eRcv()
  byte respCode;
  byte thisByte;
  int loopCount = 0;
  while(!client.available()) {
    delay(1);
    loopCount++;
    // if nothing received for 10 seconds, timeout
    if(loopCount > 10000) {
      client.stop();
      Serial.println(F("\r\nTimeout"));
      return 0;
  respCode = client.peek();
  while(client.available())
    thisByte = client.read();
    Serial.write(thisByte);
  if(respCode >= '4')
    efail();
    return 0;
  return 1;
void efail()
  byte thisByte = 0;
  int loopCount = 0;
    delay(1);
    loopCount++;
      client.stop();
      return;
  client.stop();
Is this "panicButton" connected to pin 2 and GND? If so, you must use the builtin pullup resistor. Change the keyword INPUT to INPUT_PULLUP:
  pinMode(panicButton, INPUT_PULLUP);
Thank you! That did the trick.
Craig
