loop problem
? want to do this code with the loop but ? cant please help me
int led = 2;
int led1 = 3;
int led2 = 4;
int led3 = 5;
int led4 = 6;
int hiz = 50;
  pinMode(led, OUTPUT);
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
  pinMode(led4, OUTPUT);
  digitalWrite(led, HIGH);
  delay(hiz);
  digitalWrite(led, LOW);
  delay(hiz);
  digitalWrite(led1, HIGH);
  delay(hiz);
  digitalWrite(led1, LOW);
  delay(hiz);
  digitalWrite(led2, HIGH);
  delay(hiz);
  digitalWrite(led2, LOW);
  delay(hiz);
  digitalWrite(led3, HIGH);
  delay(hiz);
  digitalWrite(led3, LOW);
  delay(hiz);
  digitalWrite(led4, HIGH);
  delay(hiz);
  digitalWrite(led4, LOW);
  delay(hiz);
  delay(hiz);
  delay(hiz);
  delay(hiz);
  delay(hiz);
  delay(hiz);
  delay(hiz);
  delay(hiz);
  delay(hiz);
it is not work
int ledPin[] = {2,3,4,5,6};
int hiz = 50;
int c=1;
  for (int i =1;i<6;i++)
    pinMode(ledPin[i], OUTPUT);
  c=c+1;
  delay(hiz);
  digitalWrite(ledPin[c], HIGH);
  delay(hiz);
  digitalWrite(ledPin[c], LOW);
  delay(hiz);
 int hiz = 50;
Are you expecting to see a difference with a 50mS delay ?
first code is working but second is not working
Arrays start at 0 not 1
Mark
When you create an array, the first index starts at zero. That's just how it is.
So for your code, ledPin[0] is 2.
The delay of 50ms is very short, you can make it 100 to be more visible.
int hiz = 50;
int c=0;
  for (int i =0; i<5 ;i++)
  for (int i=0; i<5; i++)
    digitalWrite(ledPin[i], HIGH);
    delay(hiz);
    digitalWrite(ledPin[i], LOW);
    delay(hiz);
Or you can use 'c' but you have to reset it.
Below is a different loop.
int hiz = 50;
int c=0;
  delay(hiz);
  delay(hiz);
  c++;
  if (c==5)
    c = 0;
thank you Caltoa :slight_smile:
