Loop problems
I'm having trouble with programming my uno, no matter where in the program I have a loop (for or while) when it exits the loop it is returning to void setup and essentially restarting the board any ideas? never ad any issues until recently.
Thanks in advance
Perhaps you should share your work.
Always show us your current compete sketch.
Use CTRL T to format the sketch.
Please use code tags.
Use the </> icon in the posting menu.
[code] Paste sketch here. [/code]
 //  joint position {x,y,z]
int TJ[][3] = {{ -3, 25, 0}, { -3, 25, 0}, { -3, 25, 0}, { -3, 25, 0}, { -3, 25, 0}, { -3, 25, 0}}; //posiotion relative to rotation
int TJO[][3] = {{ -3, 25, 0}, { -3, 25, 0}, { -3, 25, 0}, { -3, 25, 0}, { -3, 25, 0}, { -3, 25, 0}}; //posiotion relative to origin
int POR[] = {0, 0, 0};    // point of rotaion
int New_TJ[6][3];
int BJ[][3] = {{ -3, 25, 0}, { -3, 25, 0}, { -3, 25, 0}, { -3, 25, 0}, { -3, 25, 0}, { -3, 25, 0}};
double A[6][3] = {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}};
double X, Y, Z;
int i = 5;
int j = 0;
int roll, pitch, yaw;
int L[6];
  Serial.begin(57600);
  delay(1500);
  Serial.println("Hello");
  //while(j<6){
  ////  find relative location to POR
  //TJ[i][0]= POR[0] - TJO[i][0];
  //TJ[i][1]= POR[1] - TJO[i][1];
  //TJ[i][2]= POR[2] - TJO[i][2];
  //delay(500);
  //Serial.println("h");
  //Serial.println(j);
  //j++;
 //for (int i=0; i<=6; i++){
 ////  find angle in plane to joint from point of rotation
 //  A[i][0] = atan(TJ[i][0]/TJ[i][2]);    // roll plane angle
 //  A[i][1] = atan(TJ[i][1]/TJ[i][2]);    // pitch plane angle
 //  A[i][2] = atan(TJ[i][0]/TJ[i][1]);    // yaw plane angle
 //void loop();
 //calc new top position relative to POR
 for(int i=0; i<=6; i++){
 //  roll x,z change  //cos(angle of rotation + angle to that point from point of rotation in that plane)
 New_TJ[i][0] = cos(roll + A[i][0]) * (TJ[i][0]); //X
 New_TJ[i][2] = sin(roll + A[i][2]) * (TJ[i][2]); //Z
 //  pitch y,z change
 New_TJ[i][1] = cos(pitch + A[i][1]) * (TJ[i][1]); //Y
 New_TJ[i][2] = sin(pitch + A[i][2]) * (New_TJ[i][2]); //Z
 //  yaw x,y change
 New_TJ[i][0] = sin(yaw + A[i][0]) * (New_TJ[i][0]); //X
 New_TJ[i][1] = cos(yaw + A[i][1]) * (New_TJ[i][1]); //Y
 delay(5);
 Serial.println(i);
 Serial.println("Complete");
 delay(5);
 delay(5);
 Serial.println("found location");
 //calc length of joint****************************
 for (int i = 0; i <= 6; i++) {
   X = New_TJ[i][0] - BJ[i][0] + POR[0];
   Y = New_TJ[i][1] - BJ[i][1] + POR[0];
   Z = New_TJ[i][2] - BJ[i][2] + POR[0];
   L[i] = sqrt((X * X) + (Y * Y) + (Z * Z));
 delay(5);
 Serial.println(L[0]);
 Serial.println(L[1]);
 Serial.println(L[2]);
 Serial.println(L[3]);
 Serial.println(L[4]);
 Serial.println(L[5]);
The serial print hello the what ever is in the 1st loop i have commented in then repeats back to hello. This is in the setup so should not be repeating and it never moves on to any further code
You’re writing beyond the end of your array. There are only 6 elements and you’re trying to write to 7.
Thanks that fixed it unsure as to why that would cause a reset still but all is good
suprmek1: Thanks that fixed it unsure as to why that would cause a reset still but all is good
When you write to memory you don't own, all bets are off. Ask any of the academic staff.
Well when you write off the end of the array you overwrite some memory position where you don't know what was in that memory position. Apparently it was something pretty important and overwriting it caused a reset.
