Loop() question
jbellavance:
And so does this:
const int ledPin =  13;
int ledState = LOW;
unsigned long previousMillis;
const long interval = 1000;
char receivedChar;
boolean newData = false;
boolean blinking =  false;
 Serial.println("");
 pinMode(ledPin, OUTPUT);
 recvOneChar();
 showNewData();
 if (blinking) blink();
void blink() {
 if (currentMillis - previousMillis >= interval) {
   if (ledState == LOW) {
     ledState = HIGH;
     ledState = LOW;
   digitalWrite(ledPin, ledState);
void recvOneChar() {
 if (Serial.available() > 0) {
   receivedChar = Serial.read();
   newData = true;
void showNewData() {
 if (newData == true) {
   Serial.println(receivedChar);
   newData = false;
   if (receivedChar == 'q') blinking = true;
Yes
Set up your serial monitor to 'no line ending' characters.
A lower case q will turn on the LED (flashes), any other character will turn it off.
Not with my code. It will blink forever. That's what was asked in post #5 :wink:
Jacques
I was commenting on your "And so does this:" after my post.
Agree on what the OP asked for.
Hard to believe the OP would want to blink forever, but different stokes.
I wonder if the OP is ok!
The OP is blinking gone.
OP is fighting with blinking :slight_smile:
Thank you guys VERY MUCH, now I have new 'problem', I will post it later, about upgrading this code.
If you don't blink, you get dry eyes :cry:
You're right, eyes never been drier after hours and hours of trying to resolve this... :o
So, here is the code...
char x;
  for (int i = 0; i <= 3; i++)
    pinMode(10, OUTPUT);
  if ( Serial.available() )
    x = Serial.read();
  if ( x == 'p' )
    digitalWrite (10, HIGH);
    digitalWrite (10, LOW);
  if ( x == 'h' )
I'm trying to understand why when I'm using " if (Serial.available()) " I can get LED blink forever (until I send 'h' in this case), but when I'm using while instead of if, LED go through blinks just one time and stops...
I have this feeling that it's the other way round.
Well...
Suppose I tell you:
While you are awake, blink your eyes,
you will probably see yourself blinking your eyes all day.
And suppose I tell you:
If you see the flag rise, blink your eyes.
Now, how many times do you see yourself blink?
Jacques
If you want blink to stop... why don't you just add:
if (receivedChar == 'h') { blinking = false; digitalWrite(ledPin, LOW); }  //<<<This
to the code I sent you in post #19?
Jacques
Using delay() in your code will eventually bite you in the *ss (donkey).
Either do what Jacques suggests or use the code posted way back in #14.
