Loop script through several Variables
Hi Guys,
I've been at this arduino scripting less than a week so take it easy on me please :slight_smile:
I want to make my JSON script loop over several Strings name{1-3}, I can't see how you would loop through them, guessing some sort of array? Can someone show me some examples of how to make a script loop through a series of Variables?
I'm testing on a Wemos D1 mini.
// Libraries
#include <ESP8266WiFi.h> //Provides WiFI
#include <ArduinoJson.h> //Handles the returned JSON data
  // WiFi settings
  const char* ssid     = "VM123456789";
  const char* password = "xxx";
  //hostname
  const char* host = "jsonplaceholder.typicode.com"; //Test JSON data
  //Declare the url - may not be required.
  String url = "";
  //My Custom Strings - Loop through these might be more or less.
  String name1 = "1";
  String name2 = "2";
  String name3 = "3";
  Serial.begin(115200);   // Serial Setup
  Serial.print("Test Host: ");
  Serial.println(host);
  Serial.print("Test String: ");
  Serial.println(name1); //check String name via serial
  WiFi.begin(ssid, password); // Do wifi stuff
  Serial.println(WiFi.localIP()); //Show WiFi connection
  delay(100);
void jsonfunc(){
    WiFiClient client;
  const int httpPort = 80;
  if (!client.connect(host, httpPort)) {
     Serial.println("connection failed");
    return;
  // We now create a URI for the request
  String url = String("/todos/") +
  String(name1);
  Serial.print("URL: ");
  Serial.print(host);
  Serial.println(url);
    // This will send the request to the server
  client.print(String("GET ") + url + " HTTP/1.1\r\n" +
               "Host: " + host + "\r\n" +
               "Connection: close\r\n\r\n");
  Serial.println("Got Data...");
  // Read all the lines of the reply from server.
  String answer;
  while(client.available()){
    String line = client.readStringUntil('\r');
    answer += line;
  client.stop();
  Serial.println("closing connection");
   // Process answer
  //Serial.println("Answer: ");
  //Serial.println(answer);
  // Convert to JSON
  String jsonAnswer;
  int jsonIndex;
  for (int i = 0; i < answer.length(); i++) {
   if (answer[i] == '{') {
     jsonIndex = i;
  // Get JSON data
  jsonAnswer = answer.substring(jsonIndex);
  Serial.print("JSON answer: ");
  Serial.println(jsonAnswer);
  jsonAnswer.trim();
  //Get current currency price index data
  int rateIndex = jsonAnswer.indexOf("title");
  String result = jsonAnswer.substring(rateIndex + 10, rateIndex + 27);
  //Print Results to the serial
   Serial.print("");
   Serial.print("");
   Serial.print("Returns = ");
   Serial.println(result);
   jsonfunc(); //Call the jsonfunc Function :)
   delay(10000);//Wait before looping
Thanks for any help in advance.
P
Thanks, Delta_G,
You gave me the push I needed, I've always had a fear of Arrays, and even with my bash scripting knowledge, I've avoided it like the plague. I know they are great and I can totally see why they are used, I've just found it easier to present a list and get a for loop to process it, rather than set an array up.
Well here is my Testing Array script in case it helps someone else out struggling with making a String array as opposed to an int array I see everywhere.
#define ARRAYSIZE 3
  String itemName[ARRAYSIZE] = { "rock", "paper", "scissors" };
  Serial.println("Storing numbers in an array");
void loop(){
  for (int i =0; i< ARRAYSIZE; i++) {
  Serial.println(itemName[i]);
Which does not compile. Missing } at the end of setup()
It is usually better to let the compiler work out how many entries there are in the array
String itemName[] = { "rock", "paper", "scissors" };
const byte ARRAYSIZE = sizeof(itemName) / sizeof(itemName[0]);
  Serial.print(ARRAYSIZE);
  Serial.println(F(" entries"));
  Serial.println(F("Storing numbers in an array"));
  for (int i = 0; i < ARRAYSIZE; i++)
That way entries can be added to the array with no need to manually change the array size variable
Many (most) members here would caution against the use of Strings because of the limited memory available on most Arduinos and suggest the use of cstrings instead.
Thanks, UKHeliBob
Not sure how I dropped the "}" thanks for checking.
I will look into the c string further as I would like the program to be optimised as best I can get. I did want to make the array length dynamic but had not got to that side of things as of yet, it was on my todo :slight_smile:
The-evils-of-arduino-strings Looks to be quite a good source of info to absorb.
Thanks
P
The array length is only dynamic in the sense that the compiler works out its length at compile time. Its size cannot be changed in the program itself.
