Loop stops after a while
I've built my own arduino uno clone from a breadboard tutorial but used glassculptures and wire instead of a breadboard, so this could be a hardware problem but I don't think so, have checked it very carefully.
I want a regular blink on pin 9 and a fading of 4 neopixles on pin 11.
All works good, but the fading stops after a while (sometimes 2 hours, sometimes 15min...)
It stops in a random brightness (I think?) and stays there. The blink on pin 9 keeps gooing fine.
Could someone please check my code if there is something in it that could cause this?
Im not a good programmer at all.... Hope someone can help me, thank you so much.
#include <TimerOne.h>                //hjärtat
#include <Adafruit_NeoPixel.h>  //lungan
#define PIN 11                              //lungan
const int heart = 9;                     //hjärtat
// Parameter 1 = number of pixels in strip
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(4, 11, NEO_GRB + NEO_KHZ800);
// IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
// pixel power leads, add 300 - 500 Ohm resistor on first pixel's data input
// and minimize distance between Arduino and first pixel. Avoid connecting
// on a live circuit... if you must, connect GND first.
                                                         //lungan:
  strip.begin();
  strip.show();
                                                        //hjärtat:
pinMode(heart, OUTPUT);
Timer1.initialize(1000000);         //hur snabbt hjärtat slår 15
Timer1.pwm(heart, 70);              //hur länge varje slag lyser
                                                     //lungan:
  brighten();
  darken();
// dimrar upp från ljusstyrka 10 (25) till 255
void brighten() {
  uint16_t i, j;
  for (j = 10; j < 255; j++) {
    for (i = 0; i < strip.numPixels(); i++) {
      strip.setPixelColor(i, j, j, j);
    strip.show();
    delay(20);                                     //tid stannar i upplyst läge ? tid att dimra? 20
      Serial.println(j);
  delay(50);
// dimrar ned från 255 till 10 (25)
void darken() {
  uint16_t i, j;
  for (j = 255; j > 10; j--) {
      strip.setPixelColor(i, j, j, j);                //kall vit i, j, j, j
    strip.show();
    delay(20);
    Serial.println(j);
  delay(900); //?
How did you ever get this Serial.println(j); to work when you did set up serial begin in setup()?
Anyways:
First what does loop stops after a while mean? To figure that out a bit more info is needed.
In void setup() add in Serial.begin(115200); Set your serial monitor to the same baudrate.
In loop()
Serial.println(  "a" );
  brighten();
Serial.println(  "b" );
  darken();
When loop stops we can see if a or b is the last thing printed. Now we know more.
In
If you are asking me:
The program seems to run like it should, the LEDs work like I wanted them to. But after some time (differs how long) only the LED on pin 9 keeps going and the fading LEDs (pin 11) stops fading but are lit. After a restart everything "works" again.
If it was a retorical question:
You can't see anything contradictory straight away in the code? (sorry english is not my best language if that's not the right word). So do I get you right that you suggest I fix the serial monitor thing so I get some information on what happens when it "stops"? Why I ask if you can't see anything contradictory straight away is because I hoped you could, because I can't connect to serial monitor anymore (in an easy way). Offcourse I will do it if it is the solution. But it will need a lot of crazy unsoldering since the "Arduino" is a glass installation now: how the DIY-arduino looks
haha I didn't.. :stuck_out_tongue_closed_eyes: I don't know what happens in the serial monitor, it didn't work when I checked (offcourse).
Thank you for your help! Let me know if you think unsoldering the glasscirquitboard is the way to go.. :sweat_smile:
Is that photo of a working Arduino Uno? In glass? WOW! Love it! Art and electronics in the same object.
Can you upload the photo here please for all to see?
Sorry for a very late update. And thanks for input.
I got it to work by doing three things:
-clearing out some junk from the code, like suggested
-using a watchdog library
-and most important to make it work perfect disconnecting the analogue reference (hardware)
Here is a picture and a video link
Video (Instagram)
Edit: I also did the neo pixels run from a separate voltage supply instead of directly from the Arduino pins. Not sure if it made a difference. But I just remembered I tried it and kept it like that since it worked in combination with the other edits.
Lovely picture, can't view the video as it wants me to log in.
nice picture
could you please upload a video to youtube?
