hi all!
i have an issue that i am currently trying to debug where after running (so far between 3 - 10 hours before problems happen) it just stops communicating with the server and no longer prints messages to Serial. i am not sure which line the arduino gets stuck on and im not sure how i should handle it so ive included my sketch for anyone's review.
#include <SPI.h>
#include <Ethernet.h>
String uptime;
char data[256];
int motion;
int motion_sensor_pin = 22;
String myID = "C6";
byte myIP[4] = {192,168,230,82};
byte SM[4] = {255,255,0,0};
//byte DNS[4] = {192,168,192,216};
//byte GW[4] = {192,168,192,20};
byte mac[] = { 0xAA, 0xAD, 0xBA, 0xEF, 0xFB, 0xEB };
char server[] = "192.168.230.1";
IPAddress IP(myIP);
// fill in your Domain Name Server address here:
//IPAddress myDns(DNS);
// initialize the library instance:
EthernetClient client;
unsigned long lastConnectionTime = 0; // last time you connected to the server, in milliseconds
boolean lastConnected = false; // state of the connection last time through the main loop
const unsigned long postingInterval = 1*1000; // delay between updates, in milliseconds
// start serial port:
Serial1.begin(9600);
Serial1.setTimeout(250);
// give the ethernet module time to boot up:
// start the Ethernet connection using a fixed IP address and DNS server:
Ethernet.begin(mac, myIP);
// print the Ethernet board/shield's IP address:
Serial.print("My IP address: ");
Serial.println(Ethernet.localIP());
pinMode(motion_sensor_pin, INPUT);
// if there's incoming data from the net connection.
// send it out the serial port. This is for debugging
// purposes only:
if (client.available()) {
char c = client.read();
Serial.print(c);
// if there's no net connection, but there was one last time
// through the loop, then stop the client:
if (!client.connected() && lastConnected) {
Serial.println("disconnecting.");
client.stop();
// if you're not connected, and ten seconds have passed since
// your last connection, then connect again and send data:
if(!client.connected() && (millis() - lastConnectionTime > postingInterval)) {
httpRequest();
// store the state of the connection for next time through
// the loop:
lastConnected = client.connected();
void readCh1() {
while (Serial1.read() != -1) {}
delay(10);
Serial1.print("?");
char CRC[16];
for (int x = 0; x <= 255; x++) {
data[x] = 0;
Serial1.readBytesUntil('@',CRC,15);
Serial1.readBytesUntil('\r',data,255);
// this method makes a HTTP connection to the server:
void httpRequest() {
// if there's a successful connection:
if (client.connect(server, 80)) {
digitalWrite(motion_sensor_pin, LOW);
motion = digitalRead(motion_sensor_pin);
readCh1();
Serial.println(motion);
uptime = String(millis()/1000);
//String data = "C:28917{\"TYP\":\"DriAir\",\"IDS\":\"D19285\",\"STE\":\"RUN\",\"TMP\":4055,\"DEW\":-49,\"BRD\": 88.26,\"RUN\":1}";
String Output = "GET /mon?ID=" +myID+ "&TIME=" + uptime +"&MOTI=" + motion + "&DATA=\"" + data + "\"";
Serial.println("connecting...");
Serial.println(Output+ " HTTP/1.1");
// send the HTTP PUT request:
client.println(Output);
client.println("Host: www.arduino.cc");
client.println("User-Agent: arduino-ethernet");
client.println("Connection: close");
client.println();
// note the time that the connection was made:
lastConnectionTime = millis();
else {
// if you couldn't make a connection:
Serial.println("connection failed");
client.stop();
if anyone could help shed a little light on this i would be very grateful!!!
