I’m running a ZBee network of 1 AT coordinator and up to 4 AT routers.
All radios are Series 2 and attached to RBBB arduino boards.
The sketches on the arduinos is adapted from the examples by Rob Faludi, linked to from this page: http://www.faludi.com/itp_coursework/meshnetworking/XBee/XBee_example.html
Can anyone tell me why the coordinator code seems to run for about 6 cycles and then stop?
Thanks,
nikki
(newbie to programming, very newbie to XBee, so please bear in mind I will probably have to google your answers to be able to understand them!)
Here’s the Coordinator code:
#include <SoftwareSerial.h>
SoftwareSerial XbeeSerial(8, 7);
// a digital input is on port 12
int switchPin = 12;
// a status light is on port 13
int ledPin = 13;
// a byte to send out data:
char thisByte = 0;
void setup () {
// set pins to input and output appropriately
pinMode(ledPin, OUTPUT);
pinMode(switchPin, INPUT);
// start up the serial connection with 9600-8-n-1-true (non-inverted):
XbeeSerial.begin(9600);
// blink the status LED
blinkLED(ledPin, 3);
// for some reason it seems to help to send an arbitrary character first
//then pause for the guard time before requesting command mode
XbeeSerial.print("X");
Serial.print("X");
delay(1100);
// put the XBee in command mode
XbeeSerial.print("+++");
Serial.println("+++ setting local radio");
delay(1100);
// wait for a response from the XBee for 2000 ms, or start
// over with setup if no valid response comes
if (returnedOK() == 'T') {
// if an OK was received then continue
Serial.println("command mode acheived!");
else {
Serial.println("failed to connect");
setup(); // otherwise go back and try setup again
XbeeSerial.print("ATID2001,");
XbeeSerial.print("DH00000000,DL0000FFFF,");
// exit command mode (note that we use Serial.printLN here
//to issue a linefeed that completes the command sequence)
XbeeSerial.println("CN");
Serial.println("T");
else {
Serial.println("failed to ok");
void loop () {
// read the switch:
int startTime = millis();
while (millis() - startTime < 2000) {
thisByte = 1;
XbeeSerial.print(thisByte, DEC);
Serial.println(thisByte, DEC);
while ((millis() - startTime) >= 2000 && (millis() - startTime) < 4000) {
thisByte = 0;
} //end loop
void blinkLED(int targetPin, int numBlinks) {
// this function blinks the status LED light as many times as requested
for (int i=0; i<numBlinks; i++) {
digitalWrite(targetPin, HIGH);
Serial.println("LED HIGH"); // sets the LED on
delay(250); // waits for a second
digitalWrite(targetPin, LOW);
Serial.println("LED LOW"); // sets the LED off
delay(250);
char returnedOK () {
// this function checks the response on the serial port to see if it was an "OK" or not
char incomingChar[3];
char okString[] = "OK";
char result = 'n';
while (millis() - startTime < 2000 && result == 'n') { // use a timeout of 10 seconds
if (XbeeSerial.available() > 1) {
// read three incoming bytes which should be "O", "K", and a linefeed:
Serial.println("serial available");
for (int i=0; i<3; i++) {
incomingChar[i] = XbeeSerial.read();
if ( strstr(incomingChar, okString) != NULL ) { // check to see if the respose is "OK"
// if (incomingChar[0] == 'O' && incomingChar[1] == 'K') { // check to see if the first two characters are "OK"
result = 'T'; // return T if "OK" was the response
Serial.println("OK");
else {
result = 'F'; // otherwise return F
Serial.println("NOT OK");
return result;
And the Router code:
// an output light is on port 11
int outputPin = 13;
int ledPin = 11;
// a byte to receive data:
char inByte = 0;
void setup () {
pinMode(outputPin, OUTPUT);
Serial.print("X");
delay(1100);
delay(1100);
else {
// set the PAN (personal area network) ID number
// this example uses 0x3330, but you'll want to choose your own
// unique hexadecimal number between 0x0 and 0xFFFE
// (note the comma at the end of the command which indicates that another command will follow)
Serial.println("ATID2001, ");
// XbeeSerial.print("ATNIBLUE");
// Serial.println("ATNIBLUE");
// XbeeSerial.print("ATDNCOORD");
// Serial.println("ATDNCOORD");
// exit command mode (note that we use Serial.printLN here to issue a linefeed that completes the command sequence)
else {
void loop () {
// get any incoming data:
// read a byte
inByte = XbeeSerial.read();
// light the LED if a 1 has been received
if (inByte == '1') {
digitalWrite(outputPin, HIGH);
// douse the LED if anything else was received
else if (inByte == '0'){
digitalWrite(outputPin, LOW);
digitalWrite(targetPin, HIGH); // sets the LED on
digitalWrite(targetPin, LOW); // sets the LED off
delay(250);
Serial.print("BLINK");
Serial.println(i);
char result = 'n';
else {
return result;
