I'm kind of new with Arduino. For a school project I have to make a led run a "breathing" loop on a ESP32. This loop shoot be activated by google assistant. With some YouTube tutorials I managed to turn a LED on with google assistend (with the use of IFTT and Adafruit toggle button). I also found the code to let a led "breath" (fade in and out). Individually both the codes work on the ESP32. But when I tried to combine the codes I run into a few problems. In the VOID loop I replaced the LED going on part (from the original code) with the Breathing fade loop. When I now try to activate this loop with google assistend, the loop does run but only ones. After one fade in and out it just stays still. When I then turn the led OFF and ON again (with google assistent) it does the same thing.
I realized that it's kind of obvious that it runs only one time because the signal coming form Adafruit (activated by google assistent) is a toggle button so not a constant ON signal. So then i tried to change the IF statement in the code to a While statement. With this change the loop did work correct but I couldn't turn it off again. In the serial Moniter I also can not seem to register incoming OFF signal if I Toggle it off in Adafruit. So my question is how can I make the loop work but also let it stop correctly.
I hope it all makes sense and that somebody can help me.
I will put the code in the attachment.
Thanks!
#include <WiFi.h>
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
#define WLAN_SSID "--"
#define WLAN_PASS "--"
#define AIO_SERVER "io.adafruit.com"
#define AIO_SERVERPORT 1883
#define AIO_USERNAME "--"
#define AIO_KEY "--"
int i = 0;
const int ledPin = 16; // 16 corresponds to GPIO16
const int freq = 5000;
const int ledChannel = 0;
const int resolution = 8;
WiFiClient client; // Create an ESP8266 WiFiClient class to connect to the MQTT server.
Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY); // Setup the MQTT client class by passing in the WiFi client and MQTT server and login details.
Adafruit_MQTT_Subscribe LED_Control = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/LED_Control");
void MQTT_connect();
delay(10);
pinMode(2,OUTPUT);
// Connect to WiFi access point.
Serial.println(); Serial.println();
Serial.print("Connecting to ");
Serial.println(WLAN_SSID);
WiFi.begin(WLAN_SSID, WLAN_PASS);
Serial.print(".");
Serial.println("WiFi connected");
Serial.println("IP address: "); Serial.println(WiFi.localIP());
mqtt.subscribe(&LED_Control);
// configure LED PWM functionalitites
ledcSetup(ledChannel, freq, resolution);
// attach the channel to the GPIO to be controlled
ledcAttachPin(ledPin, ledChannel);
uint32_t x=0;
MQTT_connect();
Adafruit_MQTT_Subscribe *subscription;
while ((subscription = mqtt.readSubscription(5000))) {
if (subscription == &LED_Control) {
Serial.print(F("Got: "));
Serial.println((char *)LED_Control.lastread);
if (!strcmp((char*) LED_Control.lastread, "ON"))
for(i = 15 ; i <= 255; i+=1)
ledcWrite(ledChannel, i);
if (i > 150) {
delay(4);
if ((i > 125) && (i < 151)) {
delay(5);
if (( i > 100) && (i < 126)) {
delay(7);
if (( i > 75) && (i < 101)) {
delay(10);
if (( i > 50) && (i < 76)) {
delay(14);
if (( i > 25) && (i < 51)) {
delay(18);
if (( i > 1) && (i < 26)) {
delay(19);
for(i = 255; i >=15; i-=1)
if (i > 150) {
delay(4);
delay(5);
delay(7);
delay(10);
delay(14);
delay(18);
delay(19);
delay(970);
} else
ledcWrite(ledChannel, 0);
void MQTT_connect() {
int8_t ret;
// Stop if already connected.
if (mqtt.connected()) {
return;
Serial.print("Connecting to MQTT... ");
uint8_t retries = 3;
while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
Serial.println(mqtt.connectErrorString(ret));
Serial.println("Retrying MQTT connection in 5 seconds...");
mqtt.disconnect();
delay(5000); // wait 5 seconds
retries--;
if (retries == 0) {
// basically die and wait for WDT to reset me
while (1);
Serial.println("MQTT Connected!");
V_B_prototype.ino (3.5 KB)
