I usually have many functions in a program.
What I often end up with are 1..3 function calls in the loop, and that's it.
For example:
identify_button_pressed();
... while identify_button_pressed(x) calls measure_button_resistor(y), which calls actuate_light(z)
... and so on.
Would it be better practice to write the loop like so:
x = identify_button_pressed();
y = measure_button_resistor(x);
actuate_light(n);
I suspect the latter example shows more what is going on, rather than having to read thought the code where it is going.
So better legibility, but more intermediate variables.
The compiler will make the best sequence regardless of your sequence. Just make the code readable for you. A function calling a function makes the complete program modular. That is good.
A good rule of thumb is to have each function perform only one operation. This doesn't mean you need to write a function for every line of code - operations can be compound and quite complex. However, logically it should be one action.
Relatively speaking, if you can say “the procedure does X”, then this is the correct organization of the code. And if you have to write something like “the function is designed to do Y and Z” - then it means it’s better to divide the function into two
Perfect. But it should not activate the light. Or it should have a different name...
x is a bad name for a variable with wide scope. There is significant chance it will be used later on for a different purpose...
Inside a 5 line function it is ok...
An obligatory tip o' the hat to @paulpaulson who showed me the embedded systems name for read, evaluate and print.
As for more variables or your other cons, I did not look at your code, but if you write relentlessly forcing yourself to give variables the least scope you can, it should not be a problem.
Write good functions that use a few parameters and return values of appropriate types. You can reduce global variable use substantially; most boob noob code is lazy and ignorant around these languages features. Again, not saying that's you, I did not look at the code on offer, just wanted to say.
In my opinion it's the cleanest to separate input handling from logic and from output control
// handle any type of input
handleInputs();
// do the logic resulting in output values
doLogic();
// control the outputs based on the result of the logic
controlOutputs();
And +1 to your emphasis on the separation not only into I, P, and O, but the idea that the P part can be (wait for it)… ~100 percent free of any references to real hardware, and if done carefully, entirely possible to write to a high degree in isolation to real life issues.
What the others have said bears repeating relentlessly. Reduce complexity of your functions. IPO, absolutely. KISS.
Others may suggest "make loop() your loop, as much as you can". It took me a while to see the sense in that, but it's now very present in my code. If processing an array is bogging down, consider doing one element, or one row of a 2D array, in each pass through loop(). As a personal challenge, toggle the onboard LED each time through loop(), and strive to keep that LED appearing like it's constantly on, no blinks. For most of what we do with these small micros, it can be done. When you suddenly see blinks, think about what you've changed that slowed your code down.
Functions should get their job done, and exit promptly. No waiting around for input, no ginormous array processing. Short, sweet and snappy.
Remove delay() from your toolset. Button debounces, for example, don't get done with delay(), but can be done with millis() tests.
Which board is this? You should not have to call a wdt_reset manually. The platform's main function that calls setup and loop should do it. For example, with "esp32"
setup();
#if ARDUHAL_LOG_LEVEL >= ARDUHAL_LOG_LEVEL_DEBUG
printAfterSetupInfo();
#else
if (shouldPrintChipDebugReport()) {
#endif
for (;;) {
#if CONFIG_FREERTOS_UNICORE
yieldIfNecessary();
#endif
if (loopTaskWDTEnabled) {
esp_task_wdt_reset();
loop();
if (serialEventRun) {
serialEventRun();
