Loop through Functions
I was wondering if there is a way of having a while loop or for loop that cycles though functions if the return is = to a set result.
for example:
void myFunction(){
// loop code goes here
 Test1();
 Test2();
 Test30();
 if any of the above return False then stop and goto returnFalse()
int Test1(){
int Test30(){
trying to keep code to minimal as i have a significant amount of variable tests
mford29:
Same test repeatedly, separated in time? Different test each time with differing sensors? What exactly is being tested?
Why are the Test*() functions returning "int" not "bool"? What is "returnFalse()"?
consider
void func1 (void) { Serial.println (__func__); }
void func2 (void) { Serial.println (__func__); }
void func3 (void) { Serial.println (__func__); }
void func4 (void) { Serial.println (__func__); }
void func5 (void) { Serial.println (__func__); }
typedef void(*Func_t)(void);
Func_t funcs [] = {
    func1,
    func2,
    func3,
    func4,
    func5,
#define N_FUNC  (sizeof(funcs)/sizeof(Func_t))
void
setup (void)
    Serial.begin (9600);
    Func_t *f = funcs;
    for (unsigned n = 0; n < N_FUNC; n++)
        (*f++)();
void
loop (void)
I can't see why you'd want to obfuscate it so.
        funcs[n]();
Thanks for the replies,
Each Test is slightly different, hence in separate functions. They will be returning "PASS" or "FAIL" strings. returnFalse() is a function that will stop the loop and display where it failed.
I'm looking for a simplified part of code rather than listing all the functions with if statements after each to check the return string
TheMemberFormerlyKnownAsAWOL:
funcsn;
yes, that works as well (think you still need a "*")
gcjr:
No
