hi guys so i want to make each of the command from each hex code is looping until new hex code is received
any solutions ??
sorry if i dont post my code directly its so long and sorry if its messy, im new ![]()
sketch_MultipleLEDmodeir1.ino (10.9 KB)
any solutions ??
ADFFLAME:
hi guys so i want to make each of the command from each hex code is looping until new hex code is receivedany solutions ??
not sure this will work but in "void loop()", try taking the "switch (results.value) " case out of the "if (irrecv.decode(&results))" statement.
ie
unsigned long results_value = 0;
analogWrite(redpin, brightness_1);
analogWrite(yellowpin, brightness_2);
analogWrite(greenpin, brightness_3);
analogWrite(whitepin, brightness_4);
if (irrecv.decode(&results)) {
results_value = results.value;
irrecv.resume();
switch (results_value) {
//the rest of your switch statement here
Hopefully that does the trick! ![]()
the code was valid but unfortunately the lamp doesnt want to turn on
