hi guys i have this sketch:
#include <string.h>
#include <SPI.h>
#include <Ethernet.h>
#include <IRLib.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
byte ip[] = {192, 168, 1, 3};
byte gateway[] = {192, 168, 1, 1};
byte subnet[] = {255, 255, 255, 0};
EthernetServer server(80);
String readString;
boolean PORTONE = false;
boolean GARAGE = false;
boolean SCALA = false;
IRsend My_Sender;
int khz=38; // frequenza
//ARIA CALDA
unsigned int C30[] = {4492,4432,596,1600,592,508,592,1608,588,1608,596,504,588,508,596,1604,592,504,596,504,596,1604,592,504,600,500,592,1604,600,1600,596,504,596,1600,596,504,596,504,588,1608,596,1600,596,1604,588,1608,600,1600,592,1604,592,1604,600,1600,592,508,596,500,592,508,596,504,596,504,588,508,596,1604,588,508,596,1604,588,1608,600,1600,592,1604,592,508,592,508,596,500,592,1608,596,500,592,508,596,504,596,504,588,1608,596,1604,592,5268,4520,4424,592,1608,596,504,588,1608,596,1604,592,504,600,500,592,1608,596,500,592,508,592,1604,592,508,596,504,596,1600,596,1604,588,508,596,1604,592,504,596,504,600,1600,592,1604,592,1604,600,1600,596,1600,592,1608,588,1608,596,1604,592,504,596,504,600,500,592,508,592,504,600,500,592,1604,592,508,592,1604,592,1608,596,1600,592,1608,588,508,596,504,596,504,588,1608,596,504,600,500,592,504,596,504,588,1612,592,1604,592,1000}; //AnalysIR Batch Export - RAW
unsigned int C29[] = {4488,4436,592,1604,592,508,592,1604,592,1608,596,504,588,512,592,1604,588,512,592,504,600,1600,592,508,596,500,592,1608,596,1600,596,504,596,1600,596,504,596,504,592,1604,600,1600,592,1604,592,1608,596,1600,596,1604,592,1604,588,1612,596,500,592,508,592,508,596,500,592,508,592,508,596,1600,596,504,596,1604,592,504,596,1604,592,1604,592,508,592,508,596,500,592,1608,596,504,588,1608,600,500,592,508,592,1604,592,1604,600,5264,4516,4432,596,1600,592,508,596,1600,596,1604,588,512,592,504,600,1600,592,508,596,500,592,1608,596,504,588,508,596,1604,588,1608,596,504,592,1604,600,500,592,508,592,1604,592,1608,596,1600,596,1604,592,1604,588,1612,596,1600,592,1608,588,508,592,508,596,504,588,508,596,504,596,504,588,1608,600,500,592,1608,596,500,592,1608,596,1600,596,504,600,500,588,508,596,1604,592,508,592,1604,592,508,596,500,600,1600,596,1600,592,1000}; //AnalysIR Batch Export - RAW
unsigned int C28[] = {4496,4424,592,1608,596,504,592,1604,600,1600,592,504,600,500,592,1608,596,500,592,508,596,1604,588,508,596,504,600,1600,592,1604,592,508,592,1604,592,508,596,504,596,1600,596,1604,592,1604,600,1600,592,1604,592,1604,600,1600,596,1600,596,504,596,504,600,500,592,504,596,504,600,500,592,1604,600,500,592,508,596,504,596,1600,596,1604,588,508,596,504,600,500,592,1604,600,1600,596,1600,592,508,596,504,588,1608,596,1604,592,5268,4520,4428,600,1596,596,504,600,1600,596,1600,592,508,596,504,596,1600,596,504,600,500,592,1604,588,512,592,508,592,1604,592,1604,592,508,592,1608,588,508,596,504,596,1604,592,1604,588,1612,596,1600,592,1608,588,1608,596,1604,592,1604,588,512,592,504,600,500,588,512,592,508,596,500,600,1600,596,504,596,500,592,508,596,1604,592,1604,588,512,592,508,592,504,600,1600,596,1600,592,1608,588,508,592,508,596,1604,592,1604,588,1000}; //AnalysIR Batch Export - RAW
void setup(){
Ethernet.begin(mac, ip, gateway, subnet);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
digitalWrite(5, HIGH);
digitalWrite(6, HIGH);
digitalWrite(7, HIGH);
void loop(){
if (client) {
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
readString.concat(c);
if (c == '\n' && currentLineIsBlank) {
Serial.print(readString);
//PORTONE CASA
if(readString.indexOf("L=1") > 0) {
digitalWrite(5, LOW);
PORTONE = true;
// GARAGE
if(readString.indexOf("L=2") > 0) {
digitalWrite(6, LOW);
GARAGE = true;
//LUCE SCALA
if(readString.indexOf("L=3") > 0) {
digitalWrite(7, LOW);
SCALA = true;
// CONDIZIONATORE -- ARIA CALDA --
if(readString.indexOf("C=30") > 0)
My_Sender.IRsendRaw::send(C30, sizeof(C30)/sizeof(int), khz);
if(readString.indexOf("C=29") > 0)
My_Sender.IRsendRaw::send(C29, sizeof(C29)/sizeof(int), khz);
if(readString.indexOf("C=28") > 0)
My_Sender.IRsendRaw::send(C28, sizeof(C28)/sizeof(int), khz);
if(readString.indexOf("C=27") > 0)
My_Sender.IRsendRaw::send(C27, sizeof(C27)/sizeof(int), khz);
if(readString.indexOf("C=26") > 0)
My_Sender.IRsendRaw::send(C26, sizeof(C26)/sizeof(int), khz);
if(readString.indexOf("C=25") > 0)
My_Sender.IRsendRaw::send(C25, sizeof(C25)/sizeof(int), khz);
if(readString.indexOf("C=24") > 0)
My_Sender.IRsendRaw::send(C24, sizeof(C24)/sizeof(int), khz);
if(readString.indexOf("C=23") > 0)
My_Sender.IRsendRaw::send(C23, sizeof(C23)/sizeof(int), khz);
if(readString.indexOf("C=22") > 0)
My_Sender.IRsendRaw::send(C22, sizeof(C22)/sizeof(int), khz);
if(readString.indexOf("C=21") > 0)
My_Sender.IRsendRaw::send(C21, sizeof(C21)/sizeof(int), khz);
if(readString.indexOf("C=20") > 0)
My_Sender.IRsendRaw::send(C20, sizeof(C20)/sizeof(int), khz);
if(readString.indexOf("C=19") > 0)
My_Sender.IRsendRaw::send(C19, sizeof(C19)/sizeof(int), khz);
if(readString.indexOf("C=18") > 0)
My_Sender.IRsendRaw::send(C18, sizeof(C18)/sizeof(int), khz);
if(readString.indexOf("C=17") > 0)
My_Sender.IRsendRaw::send(C17, sizeof(C17)/sizeof(int), khz);
// CONDIZIONATORE -- ARIA FREDDA --
if(readString.indexOf("F=30") > 0)
My_Sender.IRsendRaw::send(F30, sizeof(F30)/sizeof(int), khz);
if(readString.indexOf("F=29") > 0)
My_Sender.IRsendRaw::send(F29, sizeof(F29)/sizeof(int), khz);
if(readString.indexOf("F=28") > 0)
My_Sender.IRsendRaw::send(F28, sizeof(F28)/sizeof(int), khz);
if(readString.indexOf("F=27") > 0)
My_Sender.IRsendRaw::send(F27, sizeof(F27)/sizeof(int), khz);
if(readString.indexOf("F=26") > 0)
My_Sender.IRsendRaw::send(F26, sizeof(F26)/sizeof(int), khz);
if(readString.indexOf("F=25") > 0)
My_Sender.IRsendRaw::send(F25, sizeof(F25)/sizeof(int), khz);
if(readString.indexOf("F=24") > 0)
My_Sender.IRsendRaw::send(F24, sizeof(F24)/sizeof(int), khz);
if(readString.indexOf("F=23") > 0)
My_Sender.IRsendRaw::send(F23, sizeof(F23)/sizeof(int), khz);
if(readString.indexOf("F=22") > 0)
My_Sender.IRsendRaw::send(F22, sizeof(F22)/sizeof(int), khz);
if(readString.indexOf("F=21") > 0)
My_Sender.IRsendRaw::send(F21, sizeof(F21)/sizeof(int), khz);
if(readString.indexOf("F=20") > 0)
My_Sender.IRsendRaw::send(F20, sizeof(F20)/sizeof(int), khz);
if(readString.indexOf("F=19") > 0)
My_Sender.IRsendRaw::send(F19, sizeof(F19)/sizeof(int), khz);
if(readString.indexOf("F=18") > 0)
My_Sender.IRsendRaw::send(F18, sizeof(F18)/sizeof(int), khz);
if(readString.indexOf("F=17") > 0)
My_Sender.IRsendRaw::send(F17, sizeof(F17)/sizeof(int), khz);
// INIZIO DICHIARAZIONE PAGINA HTML
client.println("Content-Type: text/html");
client.println();
client.print("<html><head><title>ARDUINO Controllo via WEB</title><meta http-equiv='Content-Type' content='text/html; charset=iso-8859-1' ></head><body>");
....continue....
There is a problem.
When i comment this part :
my webserver work. How to solve this problem?
i have cutted the code… for the forum
Thank you
