loop
hi all i am making this script where i type i and it will move a servo bye the light and o does the sweep
but it won’t loop
//Arduino Control
int delaytime = 0;
int spin;
int angle;
#include <Servo.h>
Servo myservo;
int ledPin =  13;    // LED connected to digital pin 13
int incomingByte = 0;	// for incoming serial data
int pos = 0;
// The setup() method runs once, when the sketch starts
void setup()   {
   Serial.begin(38400);
  myservo.attach(11);
  if (Serial.available() > 0) {
    // read the incoming byte:
    incomingByte = Serial.read();
    loop;
    if(incomingByte == 105){
      spin = analogRead(0);
  Serial.println(spin, DEC);
      myservo.write(spin);
    else if(incomingByte == 111){
  for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
I'm not sure what effect loop; inside loop() will have, but I'm surmising it'll just keep going back to the top of loop() every time it sees loop;.
I've never seen loop being called from inside itself before....
    loop;  // ?????????????????????????????????????????????????
I’ve never seen loop being called from inside itself before…
That isn’t calling loop. (good job too)
It’s just verifying that the function point “loop” is zero or non-zero, and then discarding the result.
All a bit pointless.
I tidied the code up (uncompiled, untested)
#include <Servo.h>
Servo myservo;
  myservo.attach(11);
    int incomingByte = Serial.read();
    if(incomingByte == 'i')
      int spin = analogRead(0);
    if(incomingByte == 'o')
      for(int pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 179 degrees
      for(int pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 1 degrees
Must confess, I have no clue what that means… what’s a “function point”?
Sorry "function pointer" - bloody auto-complete.
Well I never got as far as pointers so I still have no idea what that loop; in the middle of loop() is doing.
It's doing nothing, I just told you.
It's just like writing 42; in the middle of your code - it isn't syntactically wrong, just pointless.
