Looped Array to print as csv
Hi everyone,
I’m trying to work out how I can serial print an int array in csv format.
Can someone lead me in the right direction for an easy way to do this?
Demo Code:
int Numbers[8] = {34, 35, 36, 37, 38, 39, 40, 41};
      for (int i = 0; i < 8; i++)
        Serial.println(Numbers[i]);
Need it to print like this: 34, 35, 36, 37, 38, 39, 40, 41
Thanks in advance
You'll need one of these "Serial.print (',');"
TolpuddleSartre: You'll need one of these "Serial.print (',');"
And, you need to NOT use println().
Alrigh, what’s the problem? If you really want comma seperated instead of new line seperated you just do:
#define numberof(x) (sizeof(x)/sizeof(x[0]))
int numbers[8] = {34, 35, 36, 37, 38, 39, 40, 41}; //any reason for it being int instead of byte?
  for (byte i = 0; i < numberof(numbers); i++)
    Serial.print(numbers[i]);
    //if not last number, add a comma
    if(i != (numberof(numbers) - 1))
      Serial.print(",");
    //and a new line after all numbers`
    if(i = (numberof(numbers) - 1))
Some people would use <. YMMV.
Uhmmm, yeah. A ! disappeared :confused: You can do it with < as well, just think != represents what it does in plain text / the comment better.
septillion:
     Serial.print(",");
I can see where this is going & its what I need thanks.
But its only printing:
34, 34, 34, 34, etc
PS. still trying to get my head around byte & bits etc
All good, worked out where "!" was missing. Cheers bud
Hi Again,
How would i do this for a multidimensional array?
I have this:
  if (AlarmAddress[1][i] == 1)
    Serial.print(AlarmAddress[0][i]);
        if(i != 8 - 1)
          Serial.print(",");
septillion:
     Serial.print(",");
Thanks Again
How would i do this for a multidimensional array? I have this:
Do you want the whole array on one line, with commas? Or should each row be on a separate line?
PaulS: Do you want the whole array on one line, with commas? Or should each row be on a separate line?
The whole array on one line would be good. Thanks PaulS
You are using the value in one row to determine whether to print the value in the other row. You are not printing both rows.
You will need to make two passes through the array, counting the number of values to print on the first pass, and then printing them on the second pass.
For the second pass, replace the 8 with the number of ones counted on the first pass.
PaulS:
Im about to test it just have to rig up, is this what you mean?
    for (int j = 0; j < i; j++)
        if(j != i - 1)
          Serial.print(",");
Nope that wasn't it! I'm a little lost sorry, I keep thinking of storing the filtered results from the first pass in another array & calling that in a second for loop, but there has to be a better way I,m not seeing.
int anArray[2][3] = {{12, 13, 14}, {15, 16, 17}};
  byte bytesPerEntry = sizeof(anArray[0][0]);
  byte cols = (sizeof(anArray[0]) / bytesPerEntry);
  Serial.print("cols : ");
  Serial.println(cols);
  byte rows = ((sizeof(anArray) / cols) / bytesPerEntry);
  Serial.print("rows : ");
  Serial.println(rows);
  for (int r = 0; r < rows ; r++)
    for (int c = 0; c < cols; c++)
      Serial.print(anArray[r][c]);
      Serial.print(",");
Thanks UKHeliBob
It works well & easyish enough (for me) to understand.
I’m trying to filter out the array using a column that’s either 1 or 0 when I apply a filtering if statement to it i cant get the commas right this the best I came up with:
Has your code modified:
  int anArray[3][2] = {{12, 1}, {14, 0}, {16, 1}};
  byte count = 0;
    if (anArray[r][1] == 1)
      count++;
      Serial.print(anArray[r][0]);
      if (r <= count)
        Serial.print(",");
      if (r == rows - 1)
        count = 0;
I'm trying to filter out the array using a column that's either 1 or 0
Do you mean that if the entry is either 0 or 1 then don't output it or something else ?
Yeh I use this array with 2 columns first column is the pin number of something I’m monitoring the second is the alarm state of that pin. If an alarm is triggered the second column will change from 0 to 1 & the first column defines where the issue is (pin number). This is the filter:
if (anArray[r][1] ==1);
spark_noob: This is the filter:
Nope.
This is without any function. (if something do nothing)
Whandall: Nope.
My bad was writing from phone
