Looping conditionally in a case
I have a question; how would I loop a case until the case changes from a button press?
#include <LiquidCrystal.h>
#include <SimpleDHT.h>
int buttonValue;
int previous = HIGH;
int pin = 2;
int screenNumber = 0;
int pinDHT11 = 1;
SimpleDHT11 dht11;
int xValue, yValue;
#define joyX A1
#define joyY A2
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int rs = 12, en = 8, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
const int trigPin = 7;
const int echoPin = 6;
long duration;
int distance;
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
  pinMode(echoPin, INPUT); // Sets the echoPin as an Input
  pinMode(13, INPUT_PULLUP);
  buttonValue = digitalRead(13);
  if (buttonValue == LOW && previous == HIGH)  // Has a button just been pressed?
    switch (screenNumber)                      // Select the screen to display.
      case 0:
        lcd.clear();
        lcd.print("Joystick control");  // joystick and rgb led page
        delay(250);
        lcd.clear();
        while(buttonValue = LOW);{
            xValue = analogRead(joyX);//Reading X and Y values from joystick
  yValue = analogRead(joyY);
  lcd.setCursor(0,0);
  lcd.print("X Value : ");
  lcd.print(xValue);//Displaying xValue on top
  lcd.setCursor(0,1);
  lcd.print("Y Value : ");
  lcd.print(yValue);//Displaying yValue on bottom
      case 1:
        lcd.clear();
        lcd.print("Humidity/Temp");    // dht11 temp/humidity module page
         Serial.println("=================================");
  Serial.println("DHT11 readings...");
  byte temperature = 0;
  byte humidity = 0;
  int err = SimpleDHTErrSuccess;
  Serial.print("Readings: ");
  Serial.print((int)temperature); Serial.print(" Celcius, ");
  Serial.print((int)humidity); Serial.println(" %");
  //Telling our lcd to refresh itself every 0.75 seconds
  lcd.clear();
  //Choosing the first line and row
  lcd.setCursor(0,0);
  //Typing Temp: to the first line starting from the first row
  lcd.print("Temp: ");
  //Typing the temperature readings after "Temp: "
  lcd.print((int)temperature);
  //Choosing the second line and first row
  lcd.setCursor(0,1);
  //Typing Humidity(%): to the second line starting from the first row
  lcd.print("Humidity(%): ");
  //Typing the humidity readings after "Humidity(%): "
  lcd.print((int)humidity);
  delay(750);
      case 2:
        lcd.clear();
        lcd.print("Light level");       // photoresistor page
        delay(250);
        lcd.clear();
      int sensorValue = analogRead(A0);
 double dV = sensorValue;
 double le = (dV/1023)*100;
 int level = le;
 lcd.clear();
 lcd.setCursor(0, 0);
 lcd.print("LIGHT LEVEL:");
 lcd.print(level);
 lcd.print("%");
 lcd.setCursor(0, 1);
 if ((level >= 0) && (level <= 5))
  lcd.print("VERY DARK");
 else if ((level > 5) && (level <= 10))
  lcd.print("DARK");
 else if ((level > 10) && (level <= 50))
  lcd.print("BRIGHT");
  lcd.print("VERY BRIGHT");
      case 3:
        lcd.clear();
        lcd.print("Distance");        // ultrasonic sensor page
        delay(250);
        lcd.clear();                  // Clears the screen in preparation of new measurement
        // Clears the trigPin
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  // Sets the trigPin on HIGH state for 10 micro seconds
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  // Reads the echoPin, returns the sound wave travel time in microseconds
  duration = pulseIn(echoPin, HIGH);
  // Calculating the distance
  distance = duration * 0.034 / 2;
  // Prints the distance on the Serial Monitor
  lcd.print("Distance: ");
  lcd.print(distance);
  lcd.print(" cm");
      case 4:
        lcd.clear();
        lcd.print("IR control");          // infrared controller page
        delay(250);
        lcd.clear();
    screenNumber = (screenNumber + 1 ) % 5;    // Calculate the next screen number
  previous = buttonValue;
Not exactly sure what you are trying to do... but just having a quick look through your code there are a number of issues...
= is not the same as ==. When comparing 2 values you should use ==.
Be careful where you put ; in the line above the while statement will not execute the code in {} because you told it to stop with the ;
Be very careful declaring variables inside a switch statement (like temperature above)... you will get some very weird results. If you are going to do this make sure you enclose the full case block inside {}.
Please use the auto format tool (Control-T) to make your code just a bit easy to read.
That's a complete while statement that does nothing. Except assign the value of LOW to the variable buttonVakje.
You want == for comparison.
Also, the semicolon ends the statement. Lose it and the stuff in the { braces } will be conditionally executed.
And… if nothing changes buttonValje in the body of the loop, it will either never execute the body or get stuck executing it…
a7
And in the while loop this buttonValue = digitalRead(13); may be needed to check on the thing. Otherwise one may become stuck in the while().
Thank you so much! I'll test it when I can after I wake up!
Yeah, I had noticed lots of errors already for my sensors. Thank you so much!!!! And I will use ctrl t in the future, I hadn't known about it, sorry! :slight_smile:
Pro tip: You should not try to write code when you are asleep.
yup lmao
I have made some dumb mistakes doing that :pensive: they will haunt me forever
