Looping in case statement while looking for I2C input to change case
All,
Please see the below code.
I would like to have the cases loop and also have I2C looking for new input to change the cases.
any ideas?
Code works just fine if I send a 0 (zero) case 0 does the routine once. If I send a 1 (one) then that routine runs just once.
#include <Wire.h>
#define PIN 9
#define NUM_LEDS 14
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_RGB + NEO_KHZ800);
Wire.begin(15); // join i2c bus with address #00OF
Wire.onReceive(receiveEvent); // register event
strip.begin();
strip.show();
// Initialize the Serial interface:
void receiveEvent(int howMany) {
while (1 < Wire.available()) { // loop through all but the last
char c = Wire.read(); // receive byte as a character
Serial.print(c); // print the character
int x = Wire.read(); // receive byte as an integer
Serial.println(x); // print the integer
switch (x) {
case 0:
Serial.println("Zero");
// set pixel to red, delay(1000)
strip.setPixelColor(1, 128, 0, 0);
strip.setPixelColor(13, 128, 0, 0);
strip.setPixelColor(6, 255, 128, 0);
strip.setPixelColor(8, 255, 128, 0);
strip.show();
// set pixel to off, delay(1000)
strip.setPixelColor(1, 0, 0, 0);
strip.setPixelColor(13, 0, 0, 0);
strip.setPixelColor(6, 0, 0, 0);
strip.setPixelColor(8, 0, 0, 0);
strip.show();
case 1:
Serial.println("One");
int rr = 1;
int rl = 13;
strip.setPixelColor(0, 0, 0, 255);
strip.show();
delay(100);
strip.setPixelColor(0, 0, 0, 0);
for (int count=0; count<6; count++) {
strip.setPixelColor(rr, 0, 0, 255);
strip.setPixelColor(rl, 0, 0, 255);
strip.show();
delay(100);
strip.setPixelColor(rr++, 0, 0, 0);
strip.setPixelColor(rl--, 0, 0, 0);
strip.show();
strip.setPixelColor(rr--, 0, 0, 255);
strip.show();
delay(200);
strip.setPixelColor(rl++, 0, 0, 0);
strip.show();
strip.show();
delay(100);
strip.setPixelColor(rr--, 0, 0, 0);
strip.show();
Standard error for I2C slave:
switch (x) {
receiveEvent is called in interrupt context, so any call to a library/function that depends on interrupts to work is prohibited. Serial is such a library, delay() is such a function.
Move your code into the loop() function and just set a variable in the receiveEvent() function which you then check in loop().
