Looping incremented variable
Hi All,
I'm a newbie to Arduino. and I'm Trying some simple codes.
I try to blink a led by increasing variable 'previousMillis' :
const int ledPin = 13;
int ledState = LOW;
long previousMillis = 0;
pinMode(ledPin, OUTPUT);
previousMillis++; //incrementing variable
if (previousMillis>500) ledState=LOW; // when the value more than 500, led goes OFF
if (previousMillis==1000) { // when the value reach 1000, led goes ON
ledState=HIGH;
previousMillis=0; // set variable back to zero
digitalWrite(ledPin, ledState); // write to pin 13
but after I upload it to the board, it's not working.
then I add Serial.begin() and Serial.println() to test the variable.
int ledState = LOW;
ledState=HIGH;
Serial.println(previousMillis);
and it's WORK..
can anybody explain why the first codes is not working?
oockown:
It's working fine. It's flashing the LED every 6.62 milliseconds. It's just too fast for you to see.
The processor is pretty fast, you know.
Adding the Serial.println() just slows things down enough for you to see them, because serial comms is pretty slow.
If you change the tests to 50000 and 100000 then it is visible, although pretty fast (every 66 mS).
Try changing the limits to 500000 and 100000 - then it blinks pretty obviously. And that shows how much you can get done in a second!
ahh! yes.. it works.
Thank you very much.. :slight_smile:
Of course, if you used previousMillis as it was intended, in whatever code you "borrowed", to contain a previous value returned by millis(), you would not be having the difficulties you are.
