Basically this is what is happening
I can either send data to thingspeak but the program will not loop.
Or I can get the program to loop but not send the data to Thingspeak.
In order to have the program send data I have to remove these lines of code
client.print("Connection: close\n");
Serial.println("Connection Close");
if (client.connect(thingSpeakAddress, 80))
However when these lines are removed the program will not loop and will hang up when stating at the top of void loop.
I have a feeling that I am just missing something super simple here but have been unable to find it thus far. Any help with this would be awesome
Also sorry for the disastrous state of the code at the moment. First time coding in over 4 years so still fairly rusty.
#include <OneWire.h> //one wire DO sesnor
#include <DallasTemperature.h>
#include "RTClib.h"
#include <Wire.h> // Helps with i2c
#include <ccspi.h>
#include <string.h>
#include "utility/debug.h"
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#define DS18B20 2 //the pin you connect the ds18b20 to
#define ADAFRUIT_CC3000_IRQ 3 // MUST be an interrupt pin!
// These can be any two pins
#define ADAFRUIT_CC3000_VBAT 5
#define ADAFRUIT_CC3000_CS 10
// Use hardware SPI for the remaining pins
// On an UNO, SCK = 13, MISO = 12, and MOSI = 11
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
SPI_CLOCK_DIVIDER); // you can change this clock speed but DI
OneWire ourWire(DS18B20);
DallasTemperature sensors(&ourWire);
#define WLAN_SSID "Dreddit" // cannot be longer than 32 characters!
#define WLAN_PASS "loxg1493"
// Security can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
#define WLAN_SECURITY WLAN_SEC_WPA2
const int chipSelect = 10;
char thingSpeakAddress[] = "api.thingspeak.com";
String APIKey = "2EBZ76PBJWYEWN91"; //enter your channel's Write API Key
const int updateThingSpeakInterval = 20 * 1000; // 20 second interval at which to update ThingSpeak
long lastConnectionTime = 0;
boolean lastConnected = false;
int failedCounter = 0;
uint32_t ip;
sensors.begin();
Wire.begin();
pinMode(10, OUTPUT); //OUTPUT FOR DATA LOGGER
cc3000.begin();
char *ssid = WLAN_SSID; /* Max 32 chars */
Serial.print(F("\nAttempting to connect to ")); Serial.println(ssid);
if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
Serial.println(F("Failed!"));
while(1);
Serial.println(F("Connected!"));
Serial.println(sensors.getTempCByIndex(0));
Serial.println(F("Request DHCP"));
while (!cc3000.checkDHCP())
delay(100); // ToDo: Insert a DHCP timeout!
sensors.requestTemperatures(); // Send the command to get temperatures
Adafruit_CC3000_Client client = cc3000.connectTCP(ip, 80);
String temp = String(sensors.getTempCByIndex(0), DEC);
if (client.available())
char c = client.read();
Serial.print(c);
else {
Serial.println("Client not available");
if (!client.connected() && lastConnected)
Serial.println("...disconnected");
client.stop();
Serial.println("client not disconnected");
Serial.println(millis() - lastConnectionTime > updateThingSpeakInterval);
if(!client.connected() && (millis() - lastConnectionTime > updateThingSpeakInterval))
Serial.println("Updating Thingspeak");
updateThingSpeak("field1="+temp);
else {
Serial.println("Thingspeak not updated");
delay(60000 * 5); // 5 min delay between checks
void updateThingSpeak(String tsData) {
//if (client.connect(thingSpeakAddress, 80)) {
Serial.println("connected to TCP");
client.print("POST /update HTTP/1.1\n");
Serial.println("POST Update");
client.print("Host: api.thingspeak.com\n");
Serial.println("host");
client.print("X-THINGSPEAKAPIKEY: " + APIKey + "\n");
Serial.println("APIkey");
client.print("Content-Type: application/x-www-form-urlencoded\n");
Serial.println("Content Type");
client.print("Content-Length: ");
Serial.println("content Lentgth");
client.print(tsData.length());
Serial.println("ts.data length");
client.print("\n\n");
Serial.println("\n\n");
client.print(tsData);
lastConnectionTime = millis();
if (client.connected())
Serial.println("Connecting to ThingSpeak...");
failedCounter = 0;
failedCounter++;
Serial.println("Connection to ThingSpeak failed ("+String(failedCounter, DEC)+")");
// else
// failedCounter++;
// Serial.println("Connection to ThingSpeak Failed ("+String(failedCounter, DEC)+")");
// Serial.println();
Using IDE v1.6.8
