I have two programs, changeLights and yellowFlash. When i press a button on the IR remote i start changeLights, when i press another button i start yellowFlash. Once they've gone through the code once they stop, but i want them to loop until i press one of the two buttons again which would stop the current loop and start either the same or the other program loop.
This is what i've got so far:
#include <IRremote.h>
const int red = 10; // red led pin 10
const int yellow = 9; // yellow led pin 9
const int green = 8; // green led pin 8
const int receiver = 6; // Infrared receiver output pin( TSOP4838 )
int IRstate;
int lastIRstate;
IRrecv irrecv(receiver);
decode_results results;
Serial.println("Traffic Lights - Initializing...");
irrecv.enableIRIn();
pinMode(red, OUTPUT);
pinMode(yellow, OUTPUT);
pinMode(green, OUTPUT);
pinMode(IRstate, INPUT);
digitalWrite(red, HIGH);
digitalWrite(red, LOW);
digitalWrite(yellow, HIGH);
digitalWrite(yellow, LOW);
digitalWrite(green, HIGH);
digitalWrite(green, LOW);
Serial.println("Traffic Lights - Initialized!");
Serial.println("Waiting for remote input...");
IRstate = digitalRead(receiver);
if (IRstate != lastIRstate) {
if (irrecv.decode(&results)) {
switch(results.value) {
case 0x77E14033: // MENU
Serial.println("MENU button pressed");
yellowFlash();
case 0x77E12033: // PLAY/PAUSE
Serial.println("PLAY/PAUSE button pressed");
changeLights();
delay(10);
irrecv.resume();
lastIRstate = IRstate;
void changeLights() { // I want this to loop until i press a button on the remote
delay(3000);
delay(5000);
delay(2000);
delay(5000);
void yellowFlash() { // I want this to loop until i press a button on the remote
TheTonyy:
I think the very few changes I have made in this version will do what you want.
boolean yellowFlashRun = false; // NEW
boolean changeLightsRun = false; // NEW
int IRstate;
int lastIRstate;
yellowFlashRun = true; // NEW
changeLightsRun = true; // NEW
delay(10);
irrecv.resume();
changeLights(); // NEW
yellowFlash(); // NEW
if (changeLightsRun == true) { // new
delay(3000);
delay(5000);
delay(2000);
delay(5000);
if (yelloFlashRun == true) { // new
I think I have marked all the changes I made
Note how I have made the IR buttons set the value of variables rather than call the function directly. In effect the variable remember the button press.
Thankyou for the answers. The code you posted does do what i want it to do. Is there a way to start the other loop at any time ? Currently i can start the other loop when the current one ends.
