Looping
Can any body code this in Arduino???
i want a infinite loop that can reach a
...certain value and print it continuously like
0,1,2,3.........255,255,255,255.... to infinity...
and
255,254,253,252.... 3,2,1,0,0,0,0,0,0,0.....to infinity...
plzzz help its urgent... Thanks.
a for loop followed by a while(1) will do the trick
sorry for being a noob... but can u share a sample code here???
i tried this code but nothing is doing... :frowning:
if (option == '8' && speed1 == '5') {
        for(conspeed=0 ; conspeed<255 ; conspeed++){
      while(1){
      analogWrite(pinl1, conspeed);
      analogWrite(pinl2, 0);
      analogWrite(pinr1, conspeed);
      analogWrite(pinr2, 0);
      delay(100);
That's a while loop inside a for loop.
You need the while after the for.
or (untested, uncompiled)
  for(conspeed=0 ; 1 ; conspeed+= (conspeed <= 255) ? 1 : 0){
      delay(100);
i did this
      delay(100);
while(1){
actually i want to control motor speed from 0 to 255 when it read '5' from serial, the above code is running the motors from 0 to 255 for just one time... i want that when it reaches 255 it continuously get 255... plzz help..
this code is running
The following provides the requested result for your example value ranges. Should be easy for you to modify the start and end ranges.
    #include <limits.h>
    unsigned char   counter = 0;
    do
        counter += ((counter != UCHAR_MAX) ? 1 : 0);
        Serial.print(counter);
    } while ( true );
    unsigned char   counter = UCHAR_MAX;
    do
        counter -= ((counter != 0) ? 1 : 0);
    } while ( true );
@ lloyddean
your code ain't compiling in arduino IDE dont know y.. :frowning:
i did this
      delay(100);
while(1){
dont know y
Without you posting the error messages you're seeing and the code you've written, neither do we.
With analogWrite, whatever value was written last will remain in effect until some other value is written.
So for a ramp up (or down) function you simply run through a loop and write values from 0 to 255 with some delay between steps. Once you reach 255, you exit the loop and that's it.
The following "answer"...
a) Starts from scratch
b) Isn't EXACTLY Arduino code, but should give you the idea....
integer iCounter=0;
if (iCounter<256) {iCounter=iCounter+1;};
print iCounter;
(See also....
... Arduino programming course.)
Thanks for all your support and help... I used this code and its working fine...
main()
        int a=0;... See More
         while(1)
           printf("%d\n",a);
             if(a<255)
              a++;
...which is virtually identical to reply #4.
