loops in arduino
is it possible to have more than one loop running at a time in arduino?
I have tried various methods and none seem to work. I would like to have one loop adding values to an integer with a delay of 50 for instance, and then another loop monitoring pushbutton states with a delay of 10. If I go longer than a delay of 10 I seem to have delay in the function occuring I am trying to control with the pushbuttons.
Thanks for any help
You might want to look at the BlinkWithoutDelay example:
That's the "simple" method (good for probably most tasks); there are much more complex possibilities, up to and including some of the embeded "OS" sketches that can be loaded...
:slight_smile:
For monitoring pushbuttons you can use interrupts.
Mowcius
No.
You need a state machine:-
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1227484674
