Loops
I am writing a program where the beginning statement is a conditional statement to initiate a loop...is there a code that will only check this and not return to it again...?
In other words, is there a way to tell arduino to initialize a program based on an input but then change that input in the program itslef?
another possibility is:
Is there a way to have a conditional statement for an input that will last a certain amount of time?
If I read the question correctly, sure. For example:
int flag1;
   flag1 = InitializeSensor1();  // We assume the function returns an int
   if (flag1 != 0) {
      flag1 = 100;              // Where 100 might mean something in loop()
   } else  {
      flag1 = 0;                // Perhaps the sensor is bad
   // rest of setup()
The call to InitilizeSensor1() sets the value of flag1 to some value that makes sense for the program or 0 if the sensor is not working. Now you can use flag1 in loop() is the sensor is "good" or bypass it if it's "bad".
Thank you for the quick response, I guess I should have given some context...
I have four input switches for motor control, I want the program to start if one of them is detected as HIGH if not nothing should happen...so after setting the setup() how would I call it in loop() ?
I think the intent behind @econjack's example is to test your motor settings in setup() and set a flag accordingly.
Then the code in loop() could be
    if (startOK == false) {
       return;
   // rest of your code for when startOK is true
...R
The other way to do it would be to have a while loop in the start up function that only exits when the start condition is met.
How would that work?....Also, could it be possible to use a SwitchCase program for this scenario?
BB4DAWIN:
You have been given two suggestions. Which one are you referring to?
What are you thinking of doing with Switch Case?
I thought you just wanted a simple GO / NO-GO test to start your program (or not).
...R
BB4DAWIN:
What do you mean?
It works by stopping the program exiting the start up function until you are ready.
Do you mean how would you code this? Well it is a while loop:-
http://arduino.cc/en/Tutorial/WhileLoop
You test for your start conditions in it.
