AWOL already responded with one solution, declaring it in the call itself withvoid do_task(int num) or you can declare it like you do any other variable already, at the top of your code with simplyint num;
then... i am sorry
becaus i don't understaand what you, and AWOL are saying
i dont dow How i declair it in that, do you meen that instaed of putting the decoded values in cmd_one in do_task(num)
if zo how can i make the difrence between al the difrent ir data codes?
timothysg1:
void cmd_one() {
// do one LED sequence here
analogWrite(9, brightness);
brightness = brightness + fadeAmount;
if (millis() - lastRun > 50) {
if (brightness == 0 || brightness == 255) {
fadeAmount = -fadeAmount ;
lastRun = millis();
Something else to note: this sequence changes the LED brightness every 50 cycles.So let's do some calculations:
LED brightness goes from 0 to 255. fadeAmount is set to 5. So that's 255/5 = 51 steps to go from 0 to 255.
Steps happen every 50ms, so that's 2550ms (2.55 seconds) to go from 0 to 255 brightness. Or a little over 5 seconds to go from 0 to full brightness and back down to 0.
Given that tasks aren't precise, it will be a bit more than that, meaning the task won't run at exactly 50ms each time. it might run at 53ms, or 57ms ... everything takes time in Arduino land. So, if you're okay with a 5+ second fade on and back off, then you're good to go. If not, then lower the 50ms compare statement to a smaller number and the fade will go faster:if (millis() - lastRun > 50) // <-- change that 50 to a lower number to go faster, or larger to go slower
then... i am sorry becaus i don't understaand what you, and AWOL are saying
You've already had help defining another variable - what's the problem?
timothysg1:
then... i am sorry
Exactly the way either options are written. AWOL methodvoid do_task(int num) // <-- that declared 'num' as an INT right in the call or you can do it the other way, which is to declare the variable like you are already doing for 'lastRun' and 'RECV_PIN', just add another line that saysint num;
But do one or the other, don't do both. but you write them in exactly as they're written here. Nothing to change, nothing to substitute.
Groetjes.
AWOL:
I think the problem here is that he's never programmed before and I can certainly understand the frustration. I deal with kids in a teaching environment too and see this every day. I show them how to do something and 5 seconds later they ask the exact same thing. Patience is a virtue.
I don't mind explaining something a second time ... or third ... or ...
thats right it's the first time that i programmed
now, back to the prgramme, i have no errors but i did used the 2 at the same time
AND now it doesn't matter what butten i push on my remote my led goes one and of when i push a button again....
#include "IRremote.h"
#include "IRremoteInt.h"
int num;
long lastRun;
int RECV_PIN = 0;
IRrecv irrecv(RECV_PIN);
decode_results results;
int brightness = 0; // how bright the LED is
int fadeAmount = 5;
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
irrecv.enableIRIn();
void cmd_one() {
// if (brightness == 0 || brightness == 255) {
fadeAmount = +fadeAmount ;
lastRun = millis();
void cmd_two() {
lastRun = millis();
void do_task(int num) {
switch (num) {
case 1:
cmd_one();
case 2:
cmd_two();
// check for incoming RF data
if (irrecv.decode(&results)) {
Serial.println(results.value, HEX);
if (results.value==0x8B73AC5) {
num = 1 ;
if (results.value==0x8B77887) {
num = 2 ;
do_task(num);
irrecv.resume();
What do your debug prints tell you?
pleeze do not kill me
because i dont know what "debug prints" are/or how i find them...
You've got Serial.println statements in your sketch. They're there to show what your program is doing, in the serial monitor.
i opened that and i pushed the butten on my remote "1" and a second time the FFFFFFF in between was because i pushed them to fast
8B73AC5
FFFFFFFF
8B73AC5
Well yeah, your cmd_one() and cmd_two() are identical, so regardless of which button you push, it's doing the same thing. So change one of them to do something else. Right now you have both of them fading an LED up and down again.
Also, you need to understand that as long as 'num' does not change, the LED will continue to fade on and off indefinitely. That's how you have it coded (which was the example I gave you too.) So basically what happens is this:
You push a button, and it registers as either num = 1 or num = 2. At that point the LED will start to fade on and off. If you don't do anything after that, it will continue to fade on and off. It's not till you push another button that causes 'num' to change value, will it do something else.
If that's not the desired result, then you need to explain more about what you want them to do. From the beginning, from the moment you push a button.
Change your current cmd_one(0 and cmd_two() functions for these two, see what happens:
void cmd_one() {
// langzaam
if (millis() - lastRun > 150) {
lastRun = millis();
void cmd_two() {
// vlug
if (millis() - lastRun > 25) {
lastRun = millis();
What happens now?
if i push button "1" once the led on pin 9 lights up in his lowest setting and does notthing. he does't become brighter.
but when i push an other button of my remote (or even a button of a romote i never used) the led goes a bit brighter (only a little bit.)
so i think there ar 2 problems: he does resume to check if there are signals (otherwise the wouldn't happen anything, i think) but hie doesn't cair about the if statment in the
void loop. and he doesn't repeat cmd_one() or cmd_two()
what i try to create is a programme for a rgb ledstrip that can dim a color independently (in this i've more or less succeded, this i think i can handle), but what i don't know is how to do the following: push button 1, collors begin to fade (in a certain order, not random), push button 2 (for example) a trafic light, and so on, but al these go on if ther is no other command recieved, for example with button 1: red fades on, then green fades on then red fades off and blue fades on , green fades off , red fades on and blue fades off and this should be repeated unless these is an other command.
i am using here only pin 9 to make every thing less dificult, so i think num has to remain 1 (for ever) Unless it gets an outher command that sais num hes to be an other value
sorry that is repeat myself so muth but does it make sence?
Try this:
Connect one LED on pin 9, and another on pin 10. Then use these two functions:
void cmd_one() {
// langzaam
lastRun = millis();
void cmd_two() {
// vlug
analogWrite(10, brightness);
lastRun = millis();
And your loop has an error in it, you put do_task() inside of the if statement, it needs to be outside of it so it's constantly running. Here's a revised version:
num = 1 ;
num = 2 ;
irrecv.resume();
do_task(num);
Once you have that in place, with the two LEDs, pressing button 1 should make the LED on pin 9 fade on and off constantly. Pressing button 2 should switch to the LED on pin 10. Now, you will notice that when you press a different button, it instantly stops whatever it was doing with the previous LED, so you may end up with one LED turned on, while the other is fading on and off. Don't worry about it for now, this is just a test, see if you can even get the individual buttont on your remote to actually address two different LEDs.
thats exactly what happens, i tried some other buttons on my remote to see if there is an unexpected reaction, and ther isn't any, so far so good.
What now?
Well, the rest is up to you. I gave you the building blocks for driving two separate LEDs on two separate pins, using two separate buttons on your remote. You can fold the actions back to a single pin in which case you will only be controlling one LED, but letting it do two different things ( cmd_one() or cmd_two() ). Either way, the sky is the limit at this point. There are many way to do what you're trying to accomplish, you just have to keep playing, testing, but most of all, have fun with it.
one last thing, the line
lastRun = millis();
does it does sommething, is that what the delay resambles, or is it only because it's neccesary for the code?
You're using 'lastRun' to check the elapsed time. Remember this line: if (millis() - lastRun > 150) {
That is where it gets used. You're taking the current elapsed time from millis(), subtracting lastRun and seeing if the result is bigger than '150'. So 'lastRun' must be set each time a loop runs. Otherwise it will never reset.
i dont understaand why it doesn"t FULLY execute cmd_one
int num;
long lastRun;
int RECV_PIN = 0; // pin0 =linker poot reciever, middenste poot reciever= 5V, rechter poot reciever =grd velleman:IR38DM
int brightnessR = 0; // how bright the RED LED is
int fadeAmountR = 5;
int brightnessG = 0; // how bright the GREEN LED is
int fadeAmountG = 5;
int brightnessB = 0; // how bright the BLUE LED is
int fadeAmountB = 5;
pinMode(9, OUTPUT); //R
pinMode(10, OUTPUT); //G
pinMode(11, OUTPUT); //B
void cmd_one() {
// langzaam
analogWrite(9, brightnessR);
analogWrite(10, brightnessG);
analogWrite(11, brightnessB);
brightnessR = brightnessR + fadeAmountR; // red fades on (works fine)
if (brightnessR == 255 && brightnessB == 0) {
fadeAmountR = -fadeAmountR ; // red fades off (works fine)
brightnessG = brightnessG + fadeAmountG; // green fades on (goes on a bit but not completely)
if (brightnessG == 255 && brightnessR == 0) {
fadeAmountG = -fadeAmountG ; //green fades on (doesn't work)
brightnessB = brightnessB + fadeAmountB; // Blue fades one(doesn't work)
if(brightnessB == 255 && brightnessG == 0){
fadeAmountB = -fadeAmountB; // blue fades off(doesn't work)
lastRun = millis();
void cmd_two() {
// vlug
if (brightnessG == 0 || brightnessG == 255) {
lastRun = millis();
switch (num) {
case 1:
cmd_one();
case 2:
cmd_two();
num = 1 ;
num = 2 ;
irrecv.resume();
do_task(num);
