Your photo is out of focus bit it looks like some of the pins are bent rather than loose. How well packed was the board ?
If the pins are loose then examine their solder pads very carefully. It is possible that the pins are soldered to the solder pads OK but because they have been pushed out of shape in transit that the solder pads are no longer connected to the tracks on the PCB
Can you test the continuity between the pins and elsewhere on the PCB ?
Somethings ripped the pads off the board I think - you'll need to repair by scraping solder mask off the surrouding traces and soldering on some bodge wires to bridge to the pin - it won't be mechanically very sound though.
But the board looks pretty badly everywhere damaged, might take a lot of work.
