Hello! I want to do a confirmation for the packet received, so the packet to keep sender while the receiver is not confirmed.
The receiver is:
#include <SPI.h>
#include <LoRa.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <ThingsBoard.h> // ThingsBoard SDK
char ssid[] = "Mariani";
char pass[] = "yu-gi-oh";
#define TOKEN "JvkdK5ABO4n2LBQTc4c5"
#define THINGSBOARD_SERVER "demo.thingsboard.io"
// Initialize ThingsBoard client
WiFiClient espClient;
// Initialize ThingsBoard instance
ThingsBoard tb(espClient);
// the Wifi radio's status
int status = WL_IDLE_STATUS;
char *Bovinos[]= {"Bovino1", "Bovino2"};
while (!Serial);
WiFi.begin(ssid, pass);
InitWiFi();
Serial.println("LoRa Receiver");
LoRa.setPins(18, 14, 26);
if (!LoRa.begin(915E6)) {
Serial.println("Starting LoRa failed!");
while (1);
// try to parse packet
int packetSize = LoRa.parsePacket();
if (WiFi.status() != WL_CONNECTED) {
reconnect();
if (!tb.connected()) {
// Connect to the ThingsBoard
Serial.print("Connecting to: ");
Serial.print(THINGSBOARD_SERVER);
Serial.print(" with token ");
Serial.println(TOKEN);
if (!tb.connect(THINGSBOARD_SERVER, TOKEN)) {
Serial.println("Failed to connect");
return;
if (packetSize) {
// received a packet
Serial.print("Received packet '");
// read packet
while (LoRa.available()) {
Serial.print((char)LoRa.read());
tb.sendTelemetryFloat(Bovinos[1], (char)LoRa.read());
// print RSSI of packet
Serial.print("' with RSSI ");
Serial.println(LoRa.packetRssi());
tb.loop();
void InitWiFi()
Serial.println("Connecting to AP ...");
// attempt to connect to WiFi network
Serial.print(".");
Serial.println("Connected to AP");
void reconnect() {
// Loop until we're reconnected
status = WiFi.status();
if ( status != WL_CONNECTED) {
Serial.print(".");
The sender is:
#include <SPI.h>
#include <LoRa.h>
#include <Wire.h>
#include "HX711.h"
#define LORA_SCK 5
#define LORA_MISO 19
#define LORA_MOSI 27
#define LORA_SS 18
#define LORA_RST 14
#define LORA_DI0 26
#define LORA_BAND 915E6
#include <SPI.h>
#include <MFRC522.h>
#define RFID_SDA 5
#define RFID_SCK 18
#define RFID_MOSI 23
#define RFID_MISO 19
#define RFID_RST 22
//Pinos da HX711
#define DOUT 15
#define CLK 4
#define calibration_factor -9050.0 //Fator de Calibração da HX711
MFRC522 mfrc522(RFID_SDA, RFID_RST); // Create MFRC522 instance
HX711 scale;
int current_spi = -1; // -1 - NOT STARTED 0 - RFID 1 - LORA
float peso1;
float peso2;
String Bovinos[]= {"96:9F:01:94"};
int bovino;
String strID = "";
Serial.begin(9600); // Initialize serial communications with the PC
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
scale.begin(DOUT, CLK);
scale.set_scale(calibration_factor); //This value is obtained by using the SparkFun_HX711_Calibration sketch
scale.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
bool card_present = RFID_check();
if (card_present)
LORA_send();
void spi_select(int which) {
if (which == current_spi) return;
SPI.end();
switch(which) {
case 0:
SPI.begin(RFID_SCK, RFID_MISO, RFID_MOSI);
mfrc522.PCD_Init();
case 1:
SPI.begin(LORA_SCK,LORA_MISO,LORA_MOSI,LORA_SS);
LoRa.setPins(LORA_SS,LORA_RST,LORA_DI0);
current_spi = which;
int RFID_check() {
spi_select(0);
// Analisa a presença de novas TAGs
if (!mfrc522.PICC_IsNewCardPresent() || !mfrc522.PICC_ReadCardSerial()){ //VERIFICA SE O CARTÃO PRESENTE NO LEITOR É DIFERENTE DO ÚLTIMO CARTÃO LIDO. CASO NÃO SEJA, FAZ
return false;
/INICIO BLOCO DE CÓDIGO RESPONSÁVEL POR GERAR A TAG RFID LIDA/
for (byte i = 0; i < 4; i++) {
strID +=
(mfrc522.uid.uidByte[i] < 0x10 ? "0" : "") +
String(mfrc522.uid.uidByte[i], HEX) +
(i!=3 ? ":" : "");
strID.toUpperCase();
/FIM DO BLOCO DE CÓDIGO RESPONSÁVEL POR GERAR A TAG RFID LIDA/
//Compara o valor do ID lido com os IDs armazenados no vetor TagsCadastradas[]
for (int i = 0; i < (sizeof(Bovinos)/sizeof(String)); i++) {
if( strID.equalsIgnoreCase(Bovinos[i]) ){
//if (strID.indexOf("96:9F:01:94") >= 0) { //SE O ENDEREÇO DA TAG LIDA FOR IGUAL AO ENDEREÇO INFORMADO, FAZ
bovino=i;
peso1=scale.get_units(20);
return true;
else return false;
void LORA_send() {
spi_select(1);
Serial.println("LoRa Sender Test");
while (1);
Serial.println("init ok");
delay(1500);
// send packet
LoRa.beginPacket();
LoRa.print(peso1);
LoRa.print("Bovino: "+String(bovino)+"\n"); // Envia qual o bovino foi identificado
LoRa.print("Peso: "+String(peso1)+"kg\n"); // Envia a massa do bovino identificado.
LoRa.endPacket();
Serial.println(peso1);
delay(2000); // wait for a second
