LoRa connected Arduino UNO and ESP8266 received packets does not match
I am trying to use Arduino uno as microcontroller in the sender side and ESP8266 on the receiver side.
I am sending struct data and here's the code I am using for this project.
//Sender Arduino Uno
#include <SPI.h>
#include <LoRa.h>
struct Data {
  byte a;
  float b;
  float c;
  float d;
  float e;
  float f;
  float g;
  float h;
  float i;
Data data = {0xBB, 0, 0, 0, 0, 0, 0, 0, 0};
  while (!Serial);
  Serial.println("LoRa Sender");
  LoRa.setPins(10, 9, 2); // 10, 9 for UNO, 53, 9 for Mega, 15, 16 for ESP
  if (!LoRa.begin(433E6)) {
    Serial.println("Starting LoRa failed!");
    while (1);
  if (runEvery(4000)) { // repeat every 1000 millis
    sendMessage(); // send a message
void sendMessage() {
  LoRa.beginPacket();                   // start packet
  for (unsigned int i = 0; i < sizeof(Data);i++) {
    // Serial.print(' ');
    LoRa.write(((byte *) &data)[i]);
    // Serial.print(((byte *) &data)[i]);
  LoRa.endPacket(true);                 // finish packet and send it
  data.b += 1;
  data.c += 2;
  data.d += 3;
  data.e += 4;
  data.f += 5;
  data.g += 6;
  data.h += 7;
  data.i += 8;
  Serial.print("Node");
  Serial.print(data.a, HEX); Serial.print(",");
  Serial.print(data.b); Serial.print(",");
  Serial.print(data.c); Serial.print(",");
  Serial.print(data.d); Serial.print(",");
  Serial.print(data.e); Serial.print(",");
  Serial.print(data.f); Serial.print(",");
  Serial.print(data.g); Serial.print(",");
  Serial.print(data.h); Serial.print(",");
  Serial.print(data.i); Serial.print(",");
  Serial.println(LoRa.packetRssi());
boolean runEvery(unsigned long interval)
  static unsigned long previousMillis = 0;
  if (currentMillis - previousMillis >= interval)
    return true;
  return false;
//Receiver ESP8266
#include <SPI.h>
#include <LoRa.h>
struct Data {
  byte a;
  float b;
  float c;
  float d;
  float e;
  float f;
  float g;
  float h;
  float i;
} data;
  while (!Serial);
  Serial.println("LoRa Receiver");
  LoRa.setPins(15, 16, 2); // 10 for UNO, 53 for Mega, 15, 16 for ESP
    while (1);
  // try to parse packet
  int packetSize = LoRa.parsePacket();
  if (packetSize) {
    // received a packet
    Serial.print("Received packet '");
    // read packet
    while (LoRa.available()) {
      for (int i = 0; i < packetSize; i++) {
        ((byte *) &data)[i] = LoRa.read();
    // Serial.flush();
I printed what the sender side sents and here's the output
NodeBB,1.00,2.00,3.00,4.00,5.00,6.00,7.00,8.00,-80
NodeBB,2.00,4.00,6.00,8.00,10.00,12.00,14.00,16.00,-80
NodeBB,3.00,6.00,9.00,12.00,15.00,18.00,21.00,24.00,-80
NodeBB,4.00,8.00,12.00,16.00,20.00,24.00,28.00,32.00,-80
NodeBB,5.00,10.00,15.00,20.00,25.00,30.00,35.00,40.00,-80
NodeBB,6.00,12.00,18.00,24.00,30.00,36.00,42.00,48.00,-80
NodeBB,7.00,14.00,21.00,28.00,35.00,42.00,49.00,56.00,-80
NodeBB,8.00,16.00,24.00,32.00,40.00,48.00,56.00,64.00,-80
NodeBB,9.00,18.00,27.00,36.00,45.00,54.00,63.00,72.00,-80
NodeBB,10.00,20.00,30.00,40.00,50.00,60.00,70.00,80.00,-80
NodeBB,11.00,22.00,33.00,44.00,55.00,66.00,77.00,88.00,-80
NodeBB,12.00,24.00,36.00,48.00,60.00,72.00,84.00,96.00,-80
But I always received something like this.
Received packet 'NodeBB,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,-90
Received packet 'NodeBB,0.00,2.00,-0.00,-0.00,-2.00,-36893769622395820029.22,0.00,0.00,-90
Received packet 'NodeBB,-0.00,-2.00,0.00,0.00,2.00,36893774020442333672.06,-0.00,0.00,-90
Received packet 'NodeBB,-2.00,0.00,2.00,158457552843814264420529980270.65,-0.00,-0.00,-2.00,0.00,-90
Received packet 'NodeBB,0.00,2.00,-0.00,-0.00,-2.00,-36893774020442333672.06,0.00,0.00,-90
Received packet 'NodeBB,0.00,158457552843814264420529980270.65,-0.00,-131073.02,-158457552843814264420529980270.65,0.00,0.00,0.00,-90
Received packet 'NodeBB,2.00,-0.00,-2.00,-158457552843814264420529980270.65,0.00,0.00,2.00,0.00,-90
Received packet 'NodeBB,36893769622395820029.22,-0.00,-36893774020442333672.06,0.00,0.00,512.00,36893778418488842874.01,0.00,-90
Received packet 'NodeBB,-0.00,-2.00,0.00,0.00,2.00,36893778418488842874.01,-0.00,0.00,-90
Received packet 'NodeBB,-0.00,-562954315497472.10,0.00,0.00,562954382606336.16,2658476907804736555362978833727538585.66,-0.00,0.00,-90
Received packet 'NodeBB,-0.00,-158457552843814264420529980270.65,0.00,131073.03,158457571733280211390137992566.45,-0.00,-0.00,0.00,-90
Received packet 'NodeBB,-0.00,0.00,0.00,144116321947222036.92,-0.00,-0.00,-0.00,0.00,-90
its does not match with the expected sent data.
When I swap the microcontroller on each side, Arduino output is just 0
The code works fine as long as the microcontroller on each nodes is in the same (ex. sender and receiver microcontrollers are both Arduino (can be nano, uno or mega) or both ESP8266)
I really need ESP8266 on the receiver side because I needed the receiver side connected to the internet while on the sender side, I needed analog pins so I need to use arduino instead of esp
edit:
I tried to print the values in bytes and it is match with the sender. What must be the problem in converting values?
if I run the following code on a UNO
struct Data {
  byte a;
  float b;
  float c;
  float d;
  float e;
  float f;
  float g;
  float h;
  float i;
}data;
 Serial.println(sizeof(data));
void loop() {}
the Serial monitor displays 33 on a ESP8266 it displays 36
different processors can use different sizes for variables and different packing of variables in structures, e.g. aligned to a byte boundry or 16bit word boundry or a 32 bit boundry etc
try moving the byte to the end of the structure
struct Data {
  float b;
  float c;
  float d;
  float e;
  float f;
  float g;
  float h;
  float i;
    byte a;
}data;
this works thank you so much!
Anotther question thou, is it normal that I received 1line delayed?
this is the first time I encounter something like this
I was incrementing the sequennce number immediatly after transmitting the packet
it should be just before the packet is transmitted, e.g.
  data.seq++;               // increment packet sequence number
  LoRa_txMode();                            // set tx mode
  LoRa.write((byte *)&data, sizeof(data));  // transmit packet
  // display packet contents
  //for (unsigned int i = 0; i < sizeof(Data);i++) {
  //LoRa.write(((byte *) &data)[i]);
  data.x += 1;
  data.y += 1;
  data.z[0] += 1;
avoid uploading screen images etc they tend to be larger than equivalent text
That worked in the case of this simple struct. However it could fail with a more complex structure that has a larger mix of data types. A more general solution is to use the packed attribute:
  struct __attribute__((packed)) Data {
    byte a;
    float b;
    float c;
    float d;
    float e;
    float f;
    float g;
    float h;
    float i;
can still have problems with structure such as
    byte a;
    int k;
    float b;
    float c;
  } data;
 Serial.println(sizeof(int));
void loop() {}
on a UNO displays (int is two bytes)
11
2
on an ESP8266 (int is four bytes)
13
4
can avoid the problem by using int16_t
    byte a;
    int16_t k;
    float b;
    float c;
  } data;
data is 11 bytes on both the UNO and ESP8266
clearly when transmitting data between computers of different architectures care has to be taken
