With the help I received from the forum I eventually got my little "project" working.
The project turns pumps on and off at the correct time and so far has worked just fine.
My problem now is to get the RX unit to send info back to the TX unit. (I believe its called "Duplex").
The example Duplex in the Lora (Sanddeep) library works just fine with strings, but I face my old enemy, using Integers instead of Strings.
I have enclosed my own attempts to modify my original code to endeavour to transmit the integers
but alas it does not work.
I once again would appreciate any help in getting it to "duplex" integers.
// ...LoRa Duplex communication...
#include <SPI.h> // include libraries
#include <LoRa.h>
byte localAddress = 0xBB; // address of this device
byte destination = 0xFF; // destination to send to
int staT = 0;
int onofF = 0;
int staT2 = 0;
int onofF2 = 0;
Serial.begin(9600); // initialize serial
pinMode(7,OUTPUT);
digitalWrite(7,LOW);
pinMode(8,OUTPUT);
digitalWrite(8,LOW);
while (!Serial);
Serial.println("LoRa Duplex");
if (!LoRa.begin(915E6)) { // initialize ratio at 915 MHz
Serial.println("LoRa init failed. Check your connections.");
while (true); // if failed, do nothing
Serial.println("LoRa init succeeded.");
void TX() {
Serial.println("Sending packet: ");
Serial.println(staT);
Serial.println(onofF);
// Serial.println(timE);// NOT USED YET
//........................................TX SEND LOOP...........................
// send packets
LoRa.beginPacket();
LoRa.print("T");
LoRa.print(staT);
LoRa.print("F");
LoRa.print(onofF);
//LoRa.print("E");//NOT USED YET
//LoRa.print(timE);//NOT USED YET
LoRa.endPacket();
void RX() {
digitalWrite(7, HIGH);
char variable = LoRa.read(); // Read first char
// char variable = Serial.read(); // Read first char
switch (variable)
case 'T':
staT2 = LoRa.parseInt();
// staT = Serial.parseInt();
case 'F':
onofF2 = LoRa.parseInt();
// onofF = Serial.parseInt();
// case 'E': //.....NOT USED YET
//timE = LoRa.parseInt();
// timE = Serial.parseInt();
//break;
Serial.print(" Received "); Serial.print(staT2); Serial.print(" ... "); Serial.println(onofF2);
digitalWrite (7, LOW);
staT = 22;
onofF = 0;
digitalWrite(22, LOW);
TX();
delay (5000);
if (LoRa.parsePacket())
// if(Serial.available())
delay(100);
while (LoRa.available())
// while(Serial.available())
RX();
delay(2000);
LoRa Duplex communication wth callback
Sends a message every half second, and uses callback
for new incoming messages. Implements a one-byte addressing scheme,
with 0xFF as the broadcast address.
Note: while sending, LoRa radio is not listening for incoming messages.
Note2: when using the callback method, you can't use any of the Stream
functions that rely on the timeout, such as readString, parseInt(), etc.
created 28 April 2017
by Tom Igoe
#include <LoRa.h>
#ifdef ARDUINO_SAMD_MKRWAN1300
#error "This example is not compatible with the Arduino MKR WAN 1300 board!"
#endif
byte localAddress = 0xFF; // address of this device
byte destination = 0xBB; // destination to send to
int staT = 0;
int onofF = 0;
int staT1 = 0;
int onofF1 = 0;
pinMode(7, OUTPUT);
digitalWrite(7, LOW);
while (!Serial);
Serial.println("LoRa Duplex with callback");
// LoRa.onReceive(onReceive);
LoRa.receive();
void RX() {
switch (variable)
case 'T':
staT = LoRa.parseInt();
case 'F':
onofF = LoRa.parseInt();
//break;
Serial.print(" Received "); Serial.print(staT); Serial.print(" ... "); Serial.println(onofF);
void TX() {
//Serial.print("Sending : ");Serial.print(staT1);Serial.print(" and ");Serial.println(onofF1);
// send packets
LoRa.beginPacket();
LoRa.print("T");
LoRa.print(staT1);
LoRa.print("F");
LoRa.print(onofF1);
LoRa.endPacket();
Serial.print(" Sent Back "); Serial.print(staT1); Serial.print(" and "); Serial.println(onofF1);
delay(2000);
//LoRa.receive(); // go back into receive mode
delay(100);
RX();
delay(2000);
staT1 = 50;
onofF1 = 13;
TX();
